Home » Archived » BIRT » RAD and BIRT
RAD and BIRT [message #120253] |
Mon, 30 January 2006 20:07 |
Originally posted by: dperry.aaamissouri.com
I have been attempting to use BIRT for a few days with RAD. It seems the
report design perspective works correctly, but when I click on the preview
tab, it just hangs indefinitely. Has anyone has any success with RAD and
BIRT? I am using BIRT version 2 and RAD 6.0.1.1 which is built from
Eclipse 3.0.2.
Re: RAD and BIRT [message #120305 is a reply to message #120253] |
Mon, 30 January 2006 20:39 |
Originally posted by: elhanan.migdal-group.co.il
i don't what is RAD, but the same effect i got when i try to process a
table of 220,000 birt just kept eating my memory, used eclipse 3.1.2 here
Re: RAD and BIRT [message #120315 is a reply to message #120305] |
Mon, 30 January 2006 20:44 |
RAD is IBM's version of Eclipse. My report is small - only a few rows, but
it behaves the same way that yours does - just keeps eating up memory when I
try to preview. I can bring up my report on a stand-alone tomcat server
with birt deployed. I would like to get the preview function working
though.
"Elhanan Maayan" <elhanan@migdal-group.co.il> wrote in message
news:29d4269ac17c9ccd3749100cac83ecd8$1@www.eclipse.org...
Re: RAD and BIRT [message #120720 is a reply to message #120315] |
Tue, 31 January 2006 09:07 |
in my case both preview the run report function behave the same way (both
eat up memory.
Re: RAD and BIRT [message #122911 is a reply to message #120253] |
Wed, 01 February 2006 22:48 |
Installing BIRT with RAD should work if you do the following
1 - Download the BIRT Framework and extract to folder (e.g. c:/birt2.0)
2 - Download additional required files (iText, Axis and prototype.js) See
Birt Install page
http://www.eclipse.org/birt/phoenix/build/
Apply addition files to the directory you extracted BIRT to.
3. Navigated to the IBM Rational Links folder,
(e.g. C:\Program Files\IBM\Rational\SDP\6.0\eclipse\links)
4. Created a new link file in this directory named org.eclipse.birt.link
5. In this link file, enteredthe path to the location of BIRT 2.0, e.g.
path=c:/birt2.0
The Eclipse SDK, EMF and GEF are not needed. They should already exist.
Jason Weathersby
BIRT PMC
"Dan" <dperry@aaamissouri.com> wrote in message
news:drls1j$ekd$1@utils.eclipse.org...
> Eclipse 3.0.2.
Re: RAD and BIRT [message #127189 is a reply to message #122911] |
Thu, 09 February 2006 16:10 |
This still did not work. When I try to preview, it eats up all my CPU and
runs forever. This is just a small report that runs in 20 second or so in
Birt 1.0.
"Jason Weathersby" <jweathersby@actuate.com> wrote in message
news:drrds0$alb$1@utils.eclipse.org...
> Birt Install page
> path=c:/birt2.0
> Jason Weathersby
> BIRT PMC
preview
> > Eclipse 3.0.2.
Re: RAD and BIRT [message #127290 is a reply to message #127189] |
Thu, 09 February 2006 17:26 |
Does the same thing happen when previewing with the Web Viewer?
news:dsfpuh$ta6$1@utils.eclipse.org...
> Birt 1.0.
>> Birt Install page
>> path=c:/birt2.0
>> Jason Weathersby
>> BIRT PMC
> preview
>> > and
>> > Eclipse 3.0.2.
Re: RAD and BIRT [message #127356 is a reply to message #127290] |
Thu, 09 February 2006 17:39 |
Yes it does. It behaves like this if I click the preview tab or go to
file--> preview. If I run the Web Viewer on a Tomcat server I am able to
view the reports, but when I try to preview it runs forever. I believe the
preview uses the embedded Tomcat server like the help does. My help works
though.
I tried to switch the preview function to use the Tomcat server I have
running in RAD, but when I would try to preview, it would change ip address.
Funny thing is, the preview works fine with 1-0-1.
news:dsfu0d$585$1@utils.eclipse.org...
and
in
> > Birt 1.0.
See
> >> Birt Install page
> >> path=c:/birt2.0
exist.
> >> Jason Weathersby
> >> BIRT PMC
the
> > preview
> >> > and
> >> > Eclipse 3.0.2.
Re: RAD and BIRT [message #127565 is a reply to message #127356] |
Thu, 09 February 2006 19:12 |
Dan,
Any chance you could download Eclipse, EMF and GEF do an install with those.
create the link in the links directory and fire up a copy to see if it
works?
You shouldnt have to reinstall BIRT. This would only be for a test. If
that works than
we can look at what conflict we are having.
Jason
news:dsfv44$77g$1@utils.eclipse.org...
> the
> though.
> address.
> and
> in
>> > Birt 1.0.
>> >> c:/birt2.0)
> See
>> >> Birt Install page
>> >> e.g.
>> >> path=c:/birt2.0
> exist.
>> >> Jason Weathersby
>> >> BIRT PMC
> the
>> > preview
>> >> > and
>> >> > from
>> >> > Eclipse 3.0.2.
Re: RAD and BIRT [message #127607 is a reply to message #127565] |
Thu, 09 February 2006 19:29 |
Previously, on my second machine, I installed Eclipse 3.0.2, which is the
same version of Eclipse that RAD is built off of. I then installed Birt 2.0
and all the prerequisites. The preview functionality worked fine.
Today or tomorrow, I will do as you suggested on the machine with RAD and
report back.
news:dsg462$flp$1@utils.eclipse.org...
> Dan,
those.
> works?
> that works than
> Thanks
> Jason
to
> > the
works
> > though.
> > address.
CPU
> > and
so
> > in
> >> > Birt 1.0.
> >> >> c:/birt2.0)
prototype.js)
> > See
> >> >> Birt Install page
> >> >> e.g.
> >> >> path=c:/birt2.0
> > exist.
> >> >> Jason Weathersby
> >> >> BIRT PMC
seems
> > the
> >> > preview
RAD
> >> >> > and
> >> >> > from
> >> >> > Eclipse 3.0.2.
Re: RAD and BIRT [message #127658 is a reply to message #127565] |
Thu, 09 February 2006 20:03 |
It didn't take as long as I thought. On my RAD machine I installed Eclipse
3.0.2 along with EMF and GEF. I linked it to the same Birt 2 directory as
my RAD environment. I then copied over a report, and it previewed fine.
Any ideas?
> Dan,
those.
> works?
> that works than
> Thanks
> Jason
to
> > the
works
> > though.
> > address.
CPU
> > and
so
> > in
> >> > Birt 1.0.
> >> >> c:/birt2.0)
prototype.js)
> > See
> >> >> Birt Install page
> >> >> e.g.
> >> >> path=c:/birt2.0
> > exist.
> >> >> Jason Weathersby
> >> >> BIRT PMC
seems
> > the
> >> > preview
RAD
> >> >> > and
> >> >> > from
> >> >> > Eclipse 3.0.2.
Re: RAD and BIRT [message #127791 is a reply to message #127658] |
Thu, 09 February 2006 22:36 |
Are you getting any conflict statements in the RAD logs?
news:dsg7jn$lbl$1@utils.eclipse.org...
> Eclipse
> Any ideas?
>> Dan,
> those.
>> works?
>> that works than
>> Thanks
>> Jason
> to
>> > the
> works
>> > though.
>> > address.
> CPU
>> > and
> so
>> > in
>> >> > Birt 1.0.
>> >> >> c:/birt2.0)
> prototype.js)
>> > See
>> >> >> Birt Install page
>> >> >> e.g.
>> >> >> path=c:/birt2.0
>> > exist.
>> >> >> Jason Weathersby
>> >> >> BIRT PMC
> seems
>> > the
>> >> >> > the
>> >> > preview
> RAD
>> >> >> > and
>> >> >> > from
>> >> >> > Eclipse 3.0.2.
Re: RAD and BIRT [message #128167 is a reply to message #127791] |
Fri, 10 February 2006 16:36 |
Which log should I check?
Dan
news:dsgg62$3ps$1@utils.eclipse.org...
> > Eclipse
as
> > Any ideas?
> >> Dan,
> > those.
> >> works?
If
> >> that works than
> >> Thanks
> >> Jason
to
able
> > to
believe
> >> > the
> > works
> >> > though.
have
> >> > address.
> > CPU
> >> > and
or
> > so
> >> > in
> >> >> > Birt 1.0.
> >> >> >> c:/birt2.0)
> > prototype.js)
> >> > See
> >> >> >> Birt Install page
2.0,
> >> >> >> e.g.
> >> >> >> path=c:/birt2.0
> >> > exist.
> >> >> >> Jason Weathersby
> >> >> >> BIRT PMC
> > seems
> >> > the
> >> >> >> > the
> >> >> > preview
with
> > RAD
> >> >> >> > and
built
> >> >> >> > from
> >> >> >> > Eclipse 3.0.2.
Re: RAD and BIRT [message #128232 is a reply to message #128167] |
Fri, 10 February 2006 17:37 |
Dan,
I dont remember where the log file is generated in RAD, but on load it
creates a log file showing any problems.
When you preview there should be a log in the workspace that shows any
errors.
Jason
news:dsifq5$hhs$1@utils.eclipse.org...
> Dan
>> > Eclipse
> as
>> > fine.
>> > Any ideas?
>> >> Dan,
>> > those.
>> >> works?
> If
>> >> that works than
>> >> Thanks
>> >> Jason
> to
> able
>> > to
> believe
>> >> > the
>> > works
>> >> > though.
> have
>> >> > address.
>> >> >> > my
>> > CPU
>> >> > and
> or
>> > so
>> >> > in
>> >> >> > Birt 1.0.
>> >> >> >> c:/birt2.0)
>> > prototype.js)
>> >> > See
>> >> >> >> Birt Install page
> 2.0,
>> >> >> >> e.g.
>> >> >> >> path=c:/birt2.0
>> >> >> >> already
>> >> > exist.
>> >> >> >> Jason Weathersby
>> >> >> >> BIRT PMC
>> > seems
>> >> > the
>> >> >> >> > the
>> >> >> > preview
> with
>> > RAD
>> >> >> >> > and
> built
>> >> >> >> > from
>> >> >> >> > Eclipse 3.0.2.
Re: RAD and BIRT [message #128257 is a reply to message #128232] |
Fri, 10 February 2006 17:35 |
Where is the log in Eclipse?
news:dsij0n$rqj$1@utils.eclipse.org...
> Dan,
> errors.
> Jason
> > Dan
> >> > Eclipse
directory
> > as
> >> > fine.
> >> > Any ideas?
> >> >> Dan,
with
> >> > those.
it
> >> >> works?
> > If
> >> >> that works than
> >> >> Thanks
> >> >> Jason
go
> > to
> > able
> >> > to
> > believe
> >> >> > the
help
> >> > works
> >> >> > though.
> > have
ip
> >> >> > address.
> >> >> >> > my
> >> > CPU
> >> >> > and
second
> > or
> >> > so
> >> >> > in
> >> >> >> > Birt 1.0.
> >> >> >> >> c:/birt2.0)
> >> > prototype.js)
> >> >> > See
> >> >> >> >> Birt Install page
> > 2.0,
> >> >> >> >> e.g.
> >> >> >> >> path=c:/birt2.0
> >> >> >> >> already
> >> >> > exist.
> >> >> >> >> Jason Weathersby
> >> >> >> >> BIRT PMC
It
> >> > seems
> >> >> > the
on
> >> >> >> >> > the
> >> >> >> > preview
> > with
> >> > RAD
> >> >> >> >> > and
> > built
> >> >> >> >> > from
> >> >> >> >> > Eclipse 3.0.2.
Re: RAD and BIRT [message #128350 is a reply to message #127791] |
Fri, 10 February 2006 18:52 |
Originally posted by: to.sreddy.gmail.com
Jason,
I am trying to create a link from RAD to BIRT(both versions 1.0 and 2.0)
with BIRT 2.0
I installed RAD 6.0 and create da link to BIRT 2.0, created a
project,datasource,dataset...>
then i try to preview the result in Dataset mode, i got JVM failure error,
JVM terminated Exit code=-1073741819
with BIRT 1.0
I changed the link file path to BIRT 1.0 created dataset --> able to
preview the result in dataset mode.
Then i dragged a table from the palette and from the DataExplore view
mapped the fields from the table, and now try to preview the result.
I got the following error
HTTP Status 500 -
type Exception report
message
description The server encountered an internal error () that prevented it
from fulfilling this request.
Any clue..
Thanks.
Srini
Re: RAD and BIRT [message #128376 is a reply to message #128257] |
Fri, 10 February 2006 18:56 |
In your workspace under .metadata. Just do a search for *.log and you will
see the catalina logs.
Jason
news:dsij9q$sie$1@utils.eclipse.org...
>> Dan,
>> errors.
>> Jason
>> > Dan
>> >> > Eclipse
> directory
>> > as
>> >> > fine.
>> >> > Any ideas?
>> >> >> Dan,
> with
>> >> > those.
> it
>> >> >> works?
>> >> >> test.
>> > If
>> >> >> that works than
>> >> >> Thanks
>> >> >> Jason
> go
>> > to
>> > able
>> >> > to
>> > believe
>> >> >> > the
> help
>> >> > works
>> >> >> > though.
>> > have
> ip
>> >> >> > address.
>> >> >> >> > all
>> >> >> >> > my
>> >> > CPU
>> >> >> > and
> second
>> > or
>> >> > so
>> >> >> > in
>> >> >> >> > Birt 1.0.
>> >> >> >> >> c:/birt2.0)
>> >> > prototype.js)
>> >> >> > See
>> >> >> >> >> Birt Install page
>> > 2.0,
>> >> >> >> >> e.g.
>> >> >> >> >> path=c:/birt2.0
>> >> >> >> >> already
>> >> >> > exist.
>> >> >> >> >> Jason Weathersby
>> >> >> >> >> BIRT PMC
> It
>> >> > seems
>> >> >> > the
> on
>> >> >> >> >> > the
>> >> >> >> > preview
>> > with
>> >> > RAD
>> >> >> >> >> > and
>> > built
>> >> >> >> >> > from
>> >> >> >> >> > Eclipse 3.0.2.
Re: RAD and BIRT [message #128391 is a reply to message #128257] |
Fri, 10 February 2006 19:02 |
Dan,
You can find the log file in the following path.
...your work space/.metadata/.plugins/catalina.2006-02-10.log
Jason,
Here is my log file for HTTP 500 Error.
WebappLoader[]: Deploying class repositories to work directory
C:\RationalApplicationDeveloperTrial6.0\RADWorkSpace\.metada ta\.plugins\org.eclipse.tomcat\ROOT
ContextConfig[]: Added certificates -> request attribute Valve
StandardManager[]: Seeding random number generator class
java.security.SecureRandom
StandardManager[]: Seeding of random number generator has been completed
StandardWrapper[:default]: Loading container servlet default
StandardWrapper[:invoker]: Loading container servlet invoker
CoyoteConnector Coyote can't register jmx for protocol
WebappLoader[/viewer]: Deploying class repositories to work directory
C:\RationalApplicationDeveloperTrial6.0\RADWorkSpace\.metada ta\.plugins\org.eclipse.tomcat\viewer
WebappLoader[/viewer]: Deploy JAR /WEB-INF/lib/viewservlets.jar to
C:\ESR\Birt2.0\eclipse\plugins\org.eclipse.birt.report.viewe r_2.0.0\birt\WEB-INF\lib\viewservlets.jar
ContextConfig[/viewer]: Added certificates -> request attribute Valve
StandardManager[/viewer]: Seeding random number generator class
StandardManager[/viewer]: Seeding of random number generator has been
completed
StandardWrapper[/viewer:default]: Loading container servlet default
StandardWrapper[/viewer:invoker]: Loading container servlet invoker
completed
completed
completed
StandardWrapperValve[ViewerServlet]: Allocate exception for servlet
ViewerServlet
javax.servlet.ServletException: Error allocating a servlet instance
at
org.apache.catalina.core.StandardWrapper.allocate(StandardWr apper.java:672)
at
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:210)
at
org.apache.catalina.core.StandardPipeline$StandardPipelineVa lveContext.invokeNext(StandardPipeline.java:643)
at
org.apache.catalina.core.StandardPipeline.invoke(StandardPip eline.java:480)
at org.apache.catalina.core.ContainerBase.invoke(ContainerBase. java:995)
at
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:191)
at
at
org.apache.catalina.valves.CertificatesValve.invoke(Certific atesValve.java:246)
at
org.apache.catalina.core.StandardPipeline$StandardPipelineVa lveContext.invokeNext(StandardPipeline.java:641)
at
at
org.apache.catalina.core.StandardContext.invoke(StandardCont ext.java:2422)
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:180)
at
at
org.apache.catalina.valves.ErrorDispatcherValve.invoke(Error DispatcherValve.java:171)
at
at
org.eclipse.tomcat.internal.EclipseErrorReportValve.invoke(E clipseErrorReportValve.java:153)
at
at
at
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:174)
at
at
at org.apache.coyote.tomcat4.CoyoteAdapter.service(CoyoteAdapte r.java:199)
at
org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:828)
at
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.processConnection(Http11Protocol.java:700)
at
org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndp oint.java:584)
at
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:683)
at java.lang.Thread.run(Thread.java:813)
----- Root Cause -----
java.lang.NoClassDefFoundError: org.apache.axis.transport.http.AxisServlet
at java.lang.ClassLoader.defineClassImpl(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:211)
at java.security.SecureClassLoader.defineClass(SecureClassLoade r.java:147)
at
org.apache.catalina.loader.WebappClassLoader.findClassIntern al(WebappClassLoader.java:1679)
at
org.apache.catalina.loader.WebappClassLoader.findClass(Webap pClassLoader.java:968)
at
org.apache.catalina.loader.WebappClassLoader.loadClass(Webap pClassLoader.java:1409)
at
org.apache.catalina.loader.WebappClassLoader.loadClass(Webap pClassLoader.java:1289)
at
at
at
at
at
org.apache.catalina.core.StandardWrapper.loadServlet(Standar dWrapper.java:885)
at
org.apache.catalina.core.StandardWrapper.allocate(StandardWr apper.java:668)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
ViewerServlet
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
completed
ViewerServlet
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
ViewerServlet
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
ViewerServlet
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
ViewerServlet
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
-Srini
Re: RAD and BIRT [message #128404 is a reply to message #128257] |
Fri, 10 February 2006 19:08 |
sorry, ignore my earlier mail,
search here
...your work
space/.metadata/.plugins/org.eclipse.tomcat/catalina.2006-02 -10.log
Re: RAD and BIRT [message #128416 is a reply to message #128376] |
Fri, 10 February 2006 19:12 |
Here is the log:
C:\aaa\PolicyStarRAD\.metadata\.plugins\org.eclipse.tomcat\R OOT
C:\aaa\PolicyStarRAD\.metadata\.plugins\org.eclipse.tomcat\v iewer
WebappLoader[/viewer]: Deploy JAR /WEB-INF/lib/axis-ant.jar to
C:\birt2.0\eclipse\plugins\org.eclipse.birt.report.viewer_2. 0.0\birt\WEB-INF
\lib\axis-ant.jar
WebappLoader[/viewer]: Deploy JAR /WEB-INF/lib/axis.jar to
\lib\axis.jar
WebappLoader[/viewer]: Deploy JAR /WEB-INF/lib/commons-discovery-0.2.jar to
\lib\commons-discovery-0.2.jar
WebappLoader[/viewer]: Deploy JAR /WEB-INF/lib/jaxrpc.jar to
\lib\jaxrpc.jar
WebappLoader[/viewer]: Deploy JAR /WEB-INF/lib/saaj.jar to
\lib\saaj.jar
WebappLoader[/viewer]: Deploy JAR /WEB-INF/lib/wsdl4j-1.5.1.jar to
\lib\wsdl4j-1.5.1.jar
completed
Re: RAD and BIRT [message #128504 is a reply to message #128416] |
Fri, 10 February 2006 20:15 |
Dan
Is this all that was in the log file when previewing the report?
I dont see anything obvious. I checked which version we tried this on and
it was Birt 2.0 and RAD 6.0.
Jason
news:dsiov9$ikg$1@utils.eclipse.org...
> Here is the log:
> \lib\axis-ant.jar
> \lib\axis.jar
> to
> \lib\jaxrpc.jar
> \lib\saaj.jar
> completed
Re: RAD and BIRT [message #128517 is a reply to message #128504] |
Fri, 10 February 2006 20:23 |
That is all that is in the log. I am using RAD 6.0.1.1. I might try
rolling back to 6.0 to see if that makes a difference.
news:dsis9p$prr$1@utils.eclipse.org...
> Dan
> Jason
> > Here is the log:
> > \lib\axis-ant.jar
> > \lib\axis.jar
> > to
> > \lib\jaxrpc.jar
> > \lib\saaj.jar
> > completed
Re: RAD and BIRT [message #129344 is a reply to message #128517] |
Mon, 13 February 2006 17:06 |
The problem seems to be with IBM Rational Application Developer Fix Pack
6.0.1.1. I rolled it back and now I am able to preview with Birt 2.0.
news:dsit5b$rha$1@utils.eclipse.org...
> > Dan
and
> > Jason
> > > Here is the log:
completed
> > > \lib\axis-ant.jar
> > > \lib\axis.jar
> > > to
> > > \lib\jaxrpc.jar
> > > \lib\saaj.jar
> > > completed
Current Time: Thu Apr 25 13:09:46 GMT 2024
Powered by FUDForum. Page generated in 0.04195 seconds
