Access to GNU-Tools [message #903767] |
Sat, 25 August 2012 13:00 |
I just loaded CDT (Juno) on a W7 pro 64-bit PC which I had set up this morning. Then I downloaded and installed Codesourcery light for arm (4.6.3), and the java 32 as well as the 64-bit run time environment. Finally I copied a project from a W-XP pro PC and tried to build it. Result: Build fails because it does not find the codesourcery gcc and g++. I have used this procedure before when setting up a new 32-bit W7 pro system - and there it worked.
I finally found in Properties the entry Resource>linked resources an entry TOOLCHAIN_AT which is flagged as invalid, but I can not edit it - or more precisely: I can edit it, but when I proceed, Eclipse tells me it can not access the file .cproject. And the erreneous entry in TOOLCHAT_AT shows up again. The entry there should read C:\Program Files (86).... instead of just C:\Programme....
Any comment how to fix this or a work-around?
Thanks for help - Bob
FUDForum. Page generated in 0.05349 seconds
