Commit problems (No such Transaction/Checksum) [message #903318] |
Thu, 23 August 2012 07:15 |
Hauke Fuhrmann Messages: 333 Registered: July 2009 |
Hi there,
we have massive Subversive commit problems with a Collabnet SVN server 1.7.
We get tons of strange error messages where we cannot identify the
origin. The messages themselves do not make much sense. Committing with
other tools (e.g. Tortoise) is no problem at all. We have the problems
with both, Windows and Linux Subversive, and with the SVNKit 1.7.4,
1.7.5 and even older ones compatible to SVN 1.6.
One observation is, that all SVN commands in Subversive are very slow.
It takes about a minute to commit one single file (if it succeeds at
all), while it takes about 1 second in tortoise SVN.
Typical error messages we get most of the time are below. Do you have
any suggestions how to debug this further? At what log files can we look
(there is nothing interesting in the Server logs).
If we get the error messages, usually the commits have been succesful,
but Subversive does not recognize the success. So if we do an update
after the commit, we get the right new version.
Any hints?
Hauke
First typical message:
org.eclipse.team.svn.core.connector.SVNConnectorException: svn: E200014:
Commit failed (details follow):
svn: E200014: Base checksum mismatch on
'/trunk/src/leidisfi/build/test2.txt':
expected: 445348506b64b58cce4ec37beb4d340b
actual: bbc641225e157abb5b3d6b21dc46c648
svn: E175002: PUT of
'/svn/LeiDIS-FI/!svn/wrk/57ec4c52-3901-0010-b885-8b0c16165304/trunk/src/leidisfi/build/test2.txt':
500 Internal Server Error (http://ki-vs-svn.kiel.vst-vossloh.com)
at
org.polarion.team.svn.connector.svnkit.SVNKitConnector.handleClientException(SVNKitConnector.java:2348)
at
org.polarion.team.svn.connector.svnkit.SVNKitConnector.commit(SVNKitConnector.java:480)
at
org.eclipse.team.svn.core.extension.factory.ThreadNameModifier.commit(ThreadNameModifier.java:108)
at
org.eclipse.team.svn.core.operation.local.CommitOperation$2.run(CommitOperation.java:124)
at
org.eclipse.team.svn.core.utility.ProgressMonitorUtility.doSubTask(ProgressMonitorUtility.java:118)
at
org.eclipse.team.svn.core.operation.AbstractActionOperation.protectStep(AbstractActionOperation.java:154)
at
org.eclipse.team.svn.core.operation.AbstractActionOperation.protectStep(AbstractActionOperation.java:149)
at
org.eclipse.team.svn.core.operation.local.CommitOperation.performCommit(CommitOperation.java:122)
at
org.eclipse.team.svn.core.operation.local.CommitOperation.runImpl(CommitOperation.java:93)
at
org.eclipse.team.svn.core.operation.AbstractActionOperation.run(AbstractActionOperation.java:81)
at
org.eclipse.team.svn.core.utility.ProgressMonitorUtility.doTask(ProgressMonitorUtility.java:104)
at
org.eclipse.team.svn.core.operation.CompositeOperation.runImpl(CompositeOperation.java:95)
at
at
org.eclipse.team.svn.core.operation.LoggedOperation.run(LoggedOperation.java:39)
at
at
org.eclipse.team.svn.core.utility.ProgressMonitorUtility.doTaskExternal(ProgressMonitorUtility.java:90)
at
org.eclipse.team.svn.ui.utility.WorkspaceModifyCancellableOperationWrapper.execute(WorkspaceModifyCancellableOperationWrapper.java:58)
at
org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(WorkspaceModifyOperation.java:106)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2344)
at
org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:118)
at
org.eclipse.team.svn.ui.utility.SVNTeamOperationWrapper.run(SVNTeamOperationWrapper.java:35)
at
org.eclipse.team.internal.ui.actions.JobRunnableContext.run(JobRunnableContext.java:144)
at
org.eclipse.team.internal.ui.actions.JobRunnableContext$ResourceJob.runInWorkspace(JobRunnableContext.java:72)
at
org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java:38)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: org.apache.subversion.javahl.ClientException: svn: E200014:
at
org.apache.subversion.javahl.ClientException.fromException(ClientException.java:68)
at
org.tmatesoft.svn.core.javahl17.SVNClientImpl.getClientException(SVNClientImpl.java:1280)
at
org.tmatesoft.svn.core.javahl17.SVNClientImpl.commit(SVNClientImpl.java:583)
at
org.polarion.team.svn.connector.svnkit.SVNKitConnector.commit(SVNKitConnector.java:472)
... 23 more
Caused by: org.tmatesoft.svn.core.SVNException: svn: E200014: Commit
at
org.tmatesoft.svn.core.internal.wc.SVNErrorManager.error(SVNErrorManager.java:64)
at
org.tmatesoft.svn.core.internal.wc.SVNErrorManager.error(SVNErrorManager.java:51)
at
org.tmatesoft.svn.core.internal.wc2.ng.SvnNgCommit.doRun(SvnNgCommit.java:199)
at
org.tmatesoft.svn.core.internal.wc2.ng.SvnNgCommit.run(SvnNgCommit.java:112)
at
org.tmatesoft.svn.core.internal.wc2.ng.SvnNgCommit.run(SvnNgCommit.java:1)
at
org.tmatesoft.svn.core.internal.wc2.ng.SvnNgOperationRunner.run(SvnNgOperationRunner.java:20)
at
org.tmatesoft.svn.core.internal.wc2.SvnOperationRunner.run(SvnOperationRunner.java:20)
at
org.tmatesoft.svn.core.wc2.SvnOperationFactory.run(SvnOperationFactory.java:1235)
at org.tmatesoft.svn.core.wc2.SvnOperation.run(SvnOperation.java:291)
at org.tmatesoft.svn.core.wc2.SvnCommit.run(SvnCommit.java:184)
at
org.tmatesoft.svn.core.javahl17.SVNClientImpl.commit(SVNClientImpl.java:581)
... 24 more
Second typical message:
org.eclipse.team.svn.core.connector.SVNConnectorException: svn: E160007:
svn: E160007: No such transaction ''
svn: E175002: MERGE of
'/svn/LeiDIS-FI/trunk/src/leidisfi/build/ant4eclipse-build': 500
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Caused by: org.apache.subversion.javahl.ClientException: svn: E160007:
at
at
at
at
... 23 more
Caused by: org.tmatesoft.svn.core.SVNException: svn: E160007: Commit
at
at
at
org.tmatesoft.svn.core.internal.wc2.ng.SvnNgCommit.doRun(SvnNgCommit.java:194)
at
at
at
at
at
org.tmatesoft.svn.core.wc2.SvnOperationFactory.run(SvnOperationFactory.java:1224)
at
... 24 more
FUDForum. Page generated in 0.02562 seconds
