Home » Archived » XML Schema Definition (XSD) » How to generate XSD from XML, by restricting all the values ?(How can i create XSD from XML, by restricting all the values in XSD to the ones in the XML?)
How to generate XSD from XML, by restricting all the values ? [message #903191] Wed, 22 August 2012 13:07 Go to next message
Say, My XML is,
     <ITRForm:IncomeFromSal>1500000</ITRForm>
<ITRForm:TotalIncomeOfHP>-10000</ITRForm:TotalIncomeOfHP>
    <ITRForm:IncomeOthSrc>15000</ITRForm:IncomeOthSrc>
i need to restrict IncomeFromSal to 1500000,
In XSD, I can give,
<xs:element name="IncomeFromSal" fixed="1500000">
I've some 500 elements in my XML. I need to make all elements in XSD as, 'fixed' to the values in XML.
like
<xs:element name="TotalIncomeOfHP" fixed="-10000">
<xs:element name="IncomeOthSrc" fixed="15000">
How to do this? Can any one help me?
Re: How to generate XSD from XML, by restricting all the values ? [message #903224 is a reply to message #903191] Wed, 22 August 2012 14:28 Go to previous messageGo to next message
What have you tried so far?
On 22/08/2012 3:07 PM, sagar y wrote:
> Say, My XML is,
> In XSD, I can give,
> like
Re: How to generate XSD from XML, by restricting all the values ? [message #903308 is a reply to message #903224] Thu, 23 August 2012 06:15 Go to previous messageGo to next message
Hi Ed Merks,
Since i can restrict values by enumeration too,
I tried using int2xsd by giving enumeration attribute ,
inst2xsd -enumerations 1
but it generates XSD with enumeration to elements which have more than 1 different(at min.)
I do not get enumeration for elements which take only one value.
say My XML is
          <ITRForm:Section80GGA>2500</ITRForm:Section80GGA>
               <ITRForm:Section80GGC>3500</ITRForm:Section80GGC>
               <ITRForm:Section80U>1500</ITRForm:Section80U>
 <ITRForm:DoneePAN>SomePan11111</ITRForm:DoneePAN>
                  <ITRForm:AddressDetail>
                       <ITRForm:AddrDetail>SomePlace1111</ITRForm:AddrDetail>
<ITRForm:DoneePAN>SomePan22222</ITRForm:DoneePAN>
                       <ITRForm:AddrDetail>SomePlace2222</ITRForm:AddrDetail>
XSD is created as,
 <xs:element name="Section80GGA" type="xs:integer"/>
  <xs:element name="Section80GGC" type="xs:integer"/>
  <xs:element name="Section80U" type="xs:integer"/>
      <xs:element name="AddrDetail">
        <xs:simpleType>
          <xs:restriction base="xs:string">
            <xs:enumeration value="SomePlace1111"/>
            <xs:enumeration value="SomePlace2222"/>
             </xs:restriction>
        </xs:simpleType>
      </xs:element>
I need enumeration for Section80GGA,Section80GGC,Section80U too.
Other option is generating fixed="" attribute for elements.
Re: How to generate XSD from XML, by restricting all the values ? [message #903311 is a reply to message #903308] Thu, 23 August 2012 06:32 Go to previous messageGo to next message
Sagar,
A -inst2xsd option isn't part of the XSD project. Is this something
provided by Web Tools ore something external to Eclipse? I imagine a
schema generator tool will try to create a general schema that allows
more than just the one specific instance...
On 23/08/2012 8:15 AM, sagar y wrote:
> Hi Ed Merks,
> say My XML is
> XSD is created as,
> <xs:simpleType>
> </xs:restriction>
> </xs:simpleType>
> </xs:element>
Re: How to generate XSD from XML, by restricting all the values ? [message #903313 is a reply to message #903311] Thu, 23 August 2012 06:54 Go to previous messageGo to next message
Ed Merks,
Yeh.. inst2xsd is external to Eclipse. I tried with oxygenXml eclipse plugin. With that we can create sample XML from XSD.
Is there a way to create XSDs from XML with oxygenXml plugin?
Re: How to generate XSD from XML, by restricting all the values ? [message #903322 is a reply to message #903313] Thu, 23 August 2012 07:33 Go to previous messageGo to next message
I don't know anything about OxygenXML. Best to find an appropriate forum
to ask about that.
On 23/08/2012 8:54 AM, sagar y wrote:
> Ed Merks,
Re: How to generate XSD from XML, by restricting all the values ? [message #903518 is a reply to message #903322] Fri, 24 August 2012 06:03 Go to previous message
Ed Merks,
ok.. Thanx for responding.
Previous Topic:Maven properties and XML in Eclipse
Next Topic:one XML element value as other xml element value
Current Time: Wed Feb 19 22:09:42 GMT 2025
Powered by FUDForum. Page generated in 0.40670 seconds
