mwe-file not found building with fornax-tools [message #903151] |
Wed, 22 August 2012 09:01 |
Hi to all,
I want to use the fornax-tools to build my xtext-project with tycho.
I have the following projectlayout:
- Build
-- GenerateAllLanguages.mwe
- Project1
- Project2
-- src/vsa/....GenerateLanguage2.mwe
- Project3
- Project4
-- src/vsa/....GenerateLanguage4.mwe
With the following codesnippet I get an error Failed to execute goal org.fornax.toolsupport:fornax-oaw-m2-plugin:3.4.0:run-workflow (default) on project optimo_old: Could not find the Workflow-Descriptor "org/eclipse/xtext/xtextdoc/GenerateXTextDoc.mwe". -> [Help 1]
<!--Plugin to enable mwe2 build-->
<plugin>
<groupId>org.fornax.toolsupport</groupId>
<artifactId>fornax-oaw-m2-plugin</artifactId>
<version>3.4.0</version>
<configuration>
<outletSrcDir>src-gen</outletSrcDir>
<outletSrcOnceDir>src</outletSrcOnceDir>
<outletResOnceDir>resources</outletResOnceDir>
<workflowEngine>mwe</workflowEngine>
<workflowDescriptor>Build/scriptsGenerateAllLanguages.mwe</workflowDescriptor>
</configuration>
<executions>
<execution>
<phase>generate-sources</phase>
<goals><goal>run-workflow</goal></goals>
</execution>
</executions>
</plugin>
I start the build from parentpath of Build.
What do I have to configure to make this run?
Any help welcome
Best regards
Markus
[Updated on: Wed, 22 August 2012 09:02] Report message to a moderator
FUDForum. Page generated in 0.03506 seconds
