Home » Archived » Buckminster » Athena-style Test results
Athena-style Test results [message #903062] Tue, 21 August 2012 19:10 Go to next message
Is Buckminster able to generate Tests Results, Compile Logs,. Changes in
the same way as the old CBI Athena build.
Currently a large number of projects claim to have 0 errors, 0 warnings
on 0 tests.
e.g.
http://www.eclipse.org/modeling/emf/downloads/testResults.php?hl=1&project=emf&ID=2.8.0/R201206080554
Ed Willink
Re: Athena-style Test results [message #903099 is a reply to message #903062] Tue, 21 August 2012 21:14 Go to previous messageGo to next message
Henrik Lindberg is currently offline Henrik LindbergFriend
On 2012-21-08 21:10, Ed Willink wrote:
> Hi
Nope, sorry, out of scope for Buckminster.
> on 0 tests.
Jenkins has lots of functionality in this area - seems better to publish
results from there - or let people go directly there.
- henrik
Re: Athena-style Test results [message #903119 is a reply to message #903099] Wed, 22 August 2012 06:28 Go to previous messageGo to next message
Thomas Hallgren is currently offline Thomas HallgrenFriend
On 2012-08-21 23:14, Henrik Lindberg wrote:
> Jenkins has lots of functionality in this area - seems better to publish results from there - or let people go directly
> there.
I agree. Jenkins/Hudson has very nice capabilities that Buckminster can integrate with.
Buckminster has a test launcher that is capable of running tests directly from your workspace, just as you would by
right-clicking the test and select "Run as" -> "JUnit Plug-in Test". In order to use it you create a launcher in Eclipse
and save it by choosing "Shared file" under the "Run Configurations" tab "Common". This launcher can then be used by the
Buckminster JUnit plug-in. Here's an example that runs our own tests:
buckminster junit -P build.properties -l org.eclipse.buckminster.tests/AllTests.launch -o $WS/testReport.xml
--terseXML --flatXML
The Buckminster junit command will generate JUnit XML. We then let Hudson/Jenkins take it from there and present it
nicely. For more details, please look at the Buckminster source code at
http://git.eclipse.org/c/buckminster/buckminster.git/tree/. The projects relevant to the above command are:
org.eclipse.buckminster.releng
and, if you want the gory details of how it runs
org.eclipse.buckminster.junit
I expect that you can do make Jenkins/Hudson do nice Compile Logs as well by adding a formatter that reads the build
output. Buckminster prints all errors and warnings generated by the Eclipse builder. That includes all markers that you
would normally see in the IDE and it's not limited to just the Java compiler.
HTH,
- thomas
Re: Athena-style Test results [message #903166 is a reply to message #903119] Wed, 22 August 2012 11:07 Go to previous message
Thanks for the conformation that I/we are not doing something stupid.
I'm just a bit surprised that we've all switched over to the Buckminster
build without the corresponding support for the user reports that we
provided for many years.
Ed Willink
> well by adding a formatter that reads the build output. Buckminster
> includes all markers that you would normally see in the IDE and it's
> HTH,
Previous Topic:Resolution problems with Indigo: NPE in EclipsePlatformReaderType.getBestPlugin
Next Topic:using the target platform published by Jenkins job
Current Time: Tue Apr 16 16:34:30 GMT 2024
Powered by FUDForum. Page generated in 4.46300 seconds
