Home » Modeling » TMF (Xtext) » Can't bind IStorage2UriMapper(bind custom IStorage2UriMapper in MyDslUiModule)
Can't bind IStorage2UriMapper [message #902988] Tue, 21 August 2012 14:27 Go to next message
Sandra Shklyaeva is currently offline Sandra ShklyaevaFriend
I can't bind custom IStorage2UriMapper in MyDslUiModule.
I am trying to do the following in MyDslUiModule:
	public Class<? extends IStorage2UriMapper> bindIStorage2UriMapper() {
		return Storage2UriMapperMyDslImpl.class;
or this:
	public void configureIStorage2UriMapper(Binder binder) {
		binder.bind(IStorage2UriMapper.class)
				.annotatedWith(Names.named("Storage2UriMapperMyDslImpl"))
				.to(Storage2UriMapperMyDslImpl.class);
and also the following:
	public Provider<IStorage2UriMapper> provideIStorage2UriMapper() {
		return Access
				.<IStorage2UriMapper> provider(Storage2UriMapperMyDslImpl.class);
Unfortunately, the above doesn't work. Moreover, when I checked what interface is binded, I receive Storage2UriMapperJavaImpl.
How can I bind my Storage2UriMapperMyDslImpl?
Re: Can't bind IStorage2UriMapper [message #903050 is a reply to message #902988] Tue, 21 August 2012 18:21 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
the IStorage2UriMapper is global and thus used in the shared ui module.
=> you have to use the extension point org.eclipse.xtext.ui.shared.overridingGuiceModule
~Christian
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: Can't bind IStorage2UriMapper [message #903118 is a reply to message #903050] Wed, 22 August 2012 06:26 Go to previous message
Thank you very much Christian. Work like a charm!
Previous Topic:Type inference across inferred jvm elements
Next Topic:Couldn't find method ''_featureCall'' for objects JvmVoid
Current Time: Wed Jan 27 02:11:14 GMT 2021
Powered by FUDForum. Page generated in 0.01695 seconds
