Editor is dirty when create method returns EMPTY [message #902971] |
Tue, 21 August 2012 09:17  |
Hello everyone,
Following graphiti tutorial:
public Object[] create(ICreateContext context) {
// ask user for EClass name
String newClassName = ExampleUtil.askString(TITLE, USER_QUESTION, "");
if (newClassName == null || newClassName.trim().length() == 0) {
return EMPTY;
// create EClass
EClass newClass = EcoreFactory.eINSTANCE.createEClass();
// Add model element to resource.
// We add the model element to the resource of the diagram for
// simplicity's sake. Normally, a customer would use its own
// model persistence layer for storing the business model separately.
getDiagram().eResource().getContents().add(newClass);
newClass.setName(newClassName);
// do the add
addGraphicalRepresentation(context, newClass);
// return newly created business object(s)
return new Object[] { newClass };
When this method returns EMPTY, the editor still gets dirty despite no object was added to the resource.
Is this the expected behaviour?
Is there anyway that I can avoid this?
Joao
Re: Editor is dirty when create method returns EMPTY [message #1852475 is a reply to message #902971] |
Tue, 17 May 2022 10:53  |
This seem to work on custom Features but not when you use a Pattern.
I noticed that the CreateFeatureForPattern object always returns true and the GFCommandStack only queries the top CreateFeatureForPattern and not the actual delegated class pattern (e.g. MyCustomPattern).
So even if I override the hasDoneChanges() in my custom pattern, it has no effect. Once the Command executes the create(), the Editor will always be dirty.
Is there are a good way around this?
I see two options
a. Use a custom Create Feature - but this defeats the purpose of using a pattern, no?
b. Create your own GFCommandStack and update the execute() logic to query the delegate pattern's hasDoneChanges().
Anyone ran into a similar issue on using Patterns?
FUDForum. Page generated in 0.04399 seconds
