Home » Eclipse Projects » Riena » how-to change default submodule within module?
how-to change default submodule within module? [message #902943] Tue, 21 August 2012 10:46 Go to next message
Christian Stellwag is currently offline Christian StellwagFriend
Member
Hello Group Members,
I have modules with certain submodules within the navigation part on the left side of the Riena application.
Default-wise when i click on / open a module, the view backing the first submodule is opened.
But in one case i want to change this default behavior and have the second submodule selected on opening the module thus opening corresponding view for it.
Since I didn't find a solution anywhere, is it possible at all?
If yes, how can i accomplish it?
Chris
[Updated on: Tue, 21 August 2012 10:47]
Report message to a moderator
Re: how-to change default submodule within module? [message #902950 is a reply to message #902943] Tue, 21 August 2012 11:39 Go to previous messageGo to next message
Thorsten Schenkel is currently offline Thorsten SchenkelFriend
Hello Chris,
you can write your own ModuleController that implements your wanted functionality.
Inside your ModuleController-implementation you can add a listener to the node of the module and after the module is activated you can activate another sub-module.
Here is a very simple example:
private class Second extends SWTModuleController {
	public Second(final IModuleNode navigationNode) {
	super(navigationNode);
		navigationNode.addListener(new ModuleNodeListener() {
		public void afterActivated(final IModuleNode source) {
			super.afterActivated(source);
			final List<ISubModuleNode> children = source.getChildren();
			if (children.size() >= 1) {
				children.get(1).activate();
(Note: Extend SWTModuleController and not ModuleController)
You must add your new ModuleController to the ModuleNode.
Example:
IModuleNode playgroundModule = new ModuleNode(new NavigationNodeId("playgroundModule"), "Playground");
playgroundModule.setNavigationNodeController(new Second(playgroundModule));
This will only works, if you uses NavigationAssembler. It isn't possible with the assemblies2 extension points (org.eclipse.riena.navigation.assemblies2).
I hope this explanation helps to solve your problem.
Greetings,
Thorsten
Re: how-to change default submodule within module? [message #902959 is a reply to message #902950] Tue, 21 August 2012 12:19 Go to previous messageGo to next message
Member
Thank you very much for this solution and your quick answer, Thorsten.
Unfortunately we are using assembly2 since we have several modules representing business partners.
Is there an alternate solution for assembly2?
Is it possible to replace NavigationProcessor and would that lead to a solution?
Chris
Re: how-to change default submodule within module? [message #902967 is a reply to message #902959] Tue, 21 August 2012 12:51 Go to previous message
Member
FYI,
unexpectedly I could use your solution since I had access to the ModuleNodes when they are constructed.
So thank you very much again,
Chris
Previous Topic:Riena + Declarative Services
Next Topic:Riena counterpart of ProgressMonitorDialog
Current Time: Fri Jul 30 11:55:40 GMT 2021
Powered by FUDForum. Page generated in 0.01393 seconds
