Home » Eclipse Projects » Rich Client Platform (RCP) » Eclipse RCP errors(Eclipse RCP errors)
Eclipse RCP errors [message #902936] |
Tue, 21 August 2012 10:15 |
RP Mar Messages: 68 Registered: August 2012 |
Member |
Please kindly help me below is my errors and Please I need sample config file also.
Eclipse for RCP and RAP Developers,Version: Juno Release,Build id: 20120614-1722
!SESSION 2012-08-21 15:11:22.642 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.7.0
Framework arguments: -product ESC_Configurator_Tool.product
Command-line arguments: -product ESC_Configurator_Tool.product -data E:\Explorer/../runtime-ESC_Configurator_Tool.product -dev file:E:/Explorer/.metadata/.plugins/org.eclipse.pde.core/ESC_Configurator_Tool.product/dev.properties -os win32 -ws win32 -arch x86 -consoleLog
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-08-21 15:11:24.495
!MESSAGE Unable to retrieve the bundle from the URI: bundleclass://org.eclipse.e4.ui.workbench.addons.swt/org.eclipse.e4.ui.workbench.addons.cleanupaddon.CleanupAddon
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-08-21 15:11:24.496
!MESSAGE Unable to retrieve the bundle from the URI: bundleclass://org.eclipse.e4.ui.workbench.addons.swt/org.eclipse.e4.ui.workbench.addons.dndaddon.DnDAddon
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-08-21 15:11:24.497
!MESSAGE Unable to retrieve the bundle from the URI: bundleclass://org.eclipse.e4.ui.workbench.addons.swt/org.eclipse.e4.ui.workbench.addons.minmax.MinMaxAddon
!ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2012-08-21 15:11:24.962
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.e4.ui.workbench.swt".
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.Error: Unresolved compilation problem:
FileProperties cannot be resolved or is not a field
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:857)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:111)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:81)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.inject(ContextInjectionFactory.java:72)
at org.eclipse.ui.internal.Workbench.createWorkbenchWindow(Workbench.java:1249)
at org.eclipse.ui.internal.Workbench.getActiveWorkbenchWindow(Workbench.java:1221)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider.updateActiveShell(WorkbenchSourceProvider.java:924)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider.getCurrentState(WorkbenchSourceProvider.java:133)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider$6.handleEvent(WorkbenchSourceProvider.java:684)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1262)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1052)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1058)
at org.eclipse.swt.widgets.Decorations.WM_ACTIVATE(Decorations.java:1664)
at org.eclipse.swt.widgets.Shell.WM_ACTIVATE(Shell.java:2145)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4525)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1627)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2069)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4976)
at org.eclipse.swt.internal.win32.OS.BringWindowToTop(Native Method)
at org.eclipse.swt.widgets.Decorations.bringToTop(Decorations.java:231)
at org.eclipse.swt.widgets.Shell.open(Shell.java:1217)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.postProcess(WBWRenderer.java:710)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:639)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:725)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:696)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:690)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:675)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:961)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:916)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:585)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:540)
at esc_configurator_tool.Application.start(Application.java:20)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: java.lang.Error: Unresolved compilation problem:
at esc_configurator_tool.UpdateProperties.setUpdates(UpdateProperties.java:32)
at esc_configurator_tool.ApplicationWorkbenchWindowAdvisor.preWindowOpen(ApplicationWorkbenchWindowAdvisor.java:42)
at org.eclipse.ui.internal.WorkbenchWindow.fireWindowOpening(WorkbenchWindow.java:1209)
at org.eclipse.ui.internal.WorkbenchWindow.setup(WorkbenchWindow.java:508)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
... 53 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-08-21 15:11:24.965
!MESSAGE Exception occurred while rendering: org.eclipse.e4.ui.model.application.ui.basic.impl.TrimmedWindowImpl@7041e3 (elementId: IDEWindow, tags: [topLevel], contributorURI: platform:/plugin/org.eclipse.ui.workbench) (widget: Shell {MSI's ESC Configuration Generator}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer@49436a, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, context: TrimmedWindowImpl (IDEWindow) Context, variables: [], x: 200, y: 200, width: 1024, height: 768)
!STACK 0
... 53 more
Re: Eclipse RCP errors [message #903200 is a reply to message #902936] |
Wed, 22 August 2012 13:36 |
Oliver Koch Messages: 40 Registered: June 2012 |
Member |
this looks very weird? Why don't you check your target configuration and
your run configuration. Your run configuration must not contain any
erroneous plug-ins in your wokspace. That means you have to close the
org.eclipse.e4.ui.workbench.swt plugin if it is in your workspace and
select the one from the target platform ...
Am 21.08.2012 12:15, schrieb RP Mar:
> file also.
> 20120614-1722
> java.version=1.7.0
> java.vendor=Oracle Corporation
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 0
> compilation problem: FileProperties cannot be resolved or is not a
> field
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at
> at
> at
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> at
> at
> at
> at
> at
> ... 53 more
> mailto:org.eclipse.e4.ui.model.application.ui.basic.impl.TrimmedWindowImpl@7041e3
> mailto:org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer@49436a,
> !STACK 0
> field
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 53 more
Current Time: Fri Apr 19 05:53:35 GMT 2024
Powered by FUDForum. Page generated in 0.02972 seconds
