Using the index with an hierarchically directory tree [message #902781] |
Mon, 20 August 2012 12:09 |
Tobias Mayer Messages: 8 Registered: August 2012 |
Hello everybody,
I have some questions about the index in xtext and how to use it correctly.
In my case, an element is referable if it is on the same level or above in the directory tree (not beside / not under).
Here is a little example to better describe my concern:
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl "..."
Model:
greetings+=element*;
element:
Greeting
| RefGreetings
Greeting:
'Hello' name=ID '!';
RefGreetings:
'Ref' el = [Greeting];
The directory tree is as follows:
root
|---subdir---file2.mydsl
|---file1.mydsl
The file file1.mydsl contains the following code:
The file file2.mydsl contains the following code:
It shall be possible now to extend the file file2.mydsl to:
But it is not allowed to extend the file file1.mydsl to:
To get this behavior, I have extended the classes ResourceDescriptionsBasedContainer and SimpleResourceDescriptionsBasedContainerManager (the sourcecode is at the end of this topic). An IEObjectDescription and an IResourceDescription contain an URI. The code beneath uses a method "visible(URI candidate, URI base)" to determine whether an IEObjectDescription or an IResourceDescription is visible to the current regarded IResourceDescription.
I'm pretty sure that something is wrong with my solution because I will get the following message when testing the code:
An internal error occurred during: "Xtext validation".
java.lang.UnsupportedOperationException
My questions are:
Is this the right way to get the desired behavior?
Does anyone know how to do it correctly?
Best Regards,
Tobias
public class MySimpleResourceDescriptionsBasedContainerManager extends
SimpleResourceDescriptionsBasedContainerManager {
public IContainer getContainer(IResourceDescription desc, IResourceDescriptions resourceDescriptions) {
MyResourceDescriptionsBasedContainer result = new MyResourceDescriptionsBasedContainer(desc, resourceDescriptions);
result.setUriToDescriptionCacheEnabled(false);
return result;
public List<IContainer> getVisibleContainers(IResourceDescription desc, IResourceDescriptions resourceDescriptions) {
return Collections.singletonList(this.getContainer(desc, resourceDescriptions));
public class MyResourceDescriptionsBasedContainer extends ResourceDescriptionsBasedContainer {
protected IResourceDescription desc;
public Iterable<IEObjectDescription> getExportedObjects() {
List<IEObjectDescription> filtered = Collections.emptyList();
for (IEObjectDescription od : super.getExportedObjects())
if (this.visible(od.getEObjectURI(), desc.getURI()))
filtered.add(od);
return filtered;
public Iterable<IEObjectDescription> getExportedObjectsByType(EClass type) {
for (IEObjectDescription od : super.getExportedObjectsByType(type))
filtered.add(od);
return filtered;
public Iterable<IEObjectDescription> getExportedObjectsByObject(EObject object) {
for (IEObjectDescription od : super.getExportedObjectsByObject(object))
filtered.add(od);
return filtered;
public Iterable<IEObjectDescription> getExportedObjects(EClass type, QualifiedName qualifiedName, boolean ignoreCase) {
for (IEObjectDescription od : super.getExportedObjects(type, qualifiedName, ignoreCase))
filtered.add(od);
return filtered;
public MyResourceDescriptionsBasedContainer(IResourceDescription desc, IResourceDescriptions descriptions) {
super(descriptions);
this.desc = desc;
public Iterable<IResourceDescription> getResourceDescriptions() {
List<IResourceDescription> result = Collections.emptyList();
for (IResourceDescription element : getUriToDescription().values())
if (visible(element.getURI(), this.desc.getURI()))
result.add(element);
return result;
public int getResourceDescriptionCount() {
int counter = 0;
counter++;
return counter;
public boolean hasResourceDescription(URI uri) {
return visible(uri, this.desc.getURI());
public IResourceDescription getResourceDescription(URI uri) {
if (hasResourceDescription(uri)){
return getUriToDescription().get(uri);
/* Common Methods */
protected boolean visible(URI candidate, URI base)
boolean result = false;
List<String> uriBase = getMyDirectory(base);
List<String> uriCandidate = getMyDirectory(candidate);
if (uriCandidate.size() <= uriBase.size()) {
int limit = uriCandidate.size();
boolean equal = true;
int i = 0;
for (i = 0; i < limit && equal; i++) {
String str1 = uriBase.get(i);
String str2 = uriCandidate.get(i);
equal = str1.equals(str2);
result = equal;
return result;
protected List<String> getMyDirectory(URI paramUri) {
List<String> pathStr = paramUri.segmentsList().subList(0,
paramUri.segmentsList().size() - 1);
return pathStr;
[Updated on: Mon, 20 August 2012 12:19] Report message to a moderator
Re: Using the index with an hierarchically directory tree [message #903082 is a reply to message #902781] |
Tue, 21 August 2012 20:47 |
Sebastian Zarnekow Messages: 3118 Registered: July 2009 |
Hi Tobias,
I'd try to bind a custom IContainer.Manager to achieve the described
visibility rules, too. You're probably hit by
https://bugs.eclipse.org/bugs/show_bug.cgi?id=372041
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 20.08.12 14:09, schrieb Tobias Mayer:
> Hello everybody,
> Model:
> element:
> Greeting
> | RefGreetings
> Greeting:
> RefGreetings:
> root
> |---file1.mydsl
> Hello test1!
> Hello test2!
> Hello test2!
> Ref test1
> Hello test1!
> Ref test2
> My questions are:
> Best Regards,
> Tobias
FUDForum. Page generated in 0.03895 seconds
