Home » Newcomers » Newcomers » I need help(eclipse emf java to xml Persistence)
I need help [message #902729] Mon, 20 August 2012 07:37 Go to next message
firefly hoo is currently offline firefly hooFriend
Could not open the editor: org.eclipse.emf.ecore.xmi.FeatureNotFoundException: Feature 'log-enable' not found. (platform:/resource/eclipse_vs/kcmvc/com/coollf/eaylist/sa.trans, 7, 17)
in my xsd file i definition
a log-enable element i want to make a xml editer for eclipse pulg
but i encounter this question ,i know just log-enable change over log_enable or logEnable
but it will An enormous consequences
Re: I need help [message #902745 is a reply to message #902729] Mon, 20 August 2012 08:54 Go to previous messageGo to next message
What is sa.trans? Is it a file for which you have an EMF model? Did you
add a log-enable element or attribute to that file? Did you update the
model so it knows there's a corresponding feature for that tag?
Ed Merks
Re: I need help [message #902937 is a reply to message #902745] Tue, 21 August 2012 10:23 Go to previous messageGo to next message
I'm just trying to make a eclipse plugin ,
sa.trans is my plugin created file.
because it have a node name is 'log-enable' look like this:
<trans>
<tran>
<id>docket_inventory_to_delivery_and_enter</id>
<name>XXX</name>
<enable>true</enable>
<log-enable>true</log-enable>
<src/>
<tran>
</trans>
this file this my editor created ;
but i can't afresh open sa.trans on my editor .
Re: I need help [message #902953 is a reply to message #902937] Tue, 21 August 2012 11:47 Go to previous message
The exception makes it look like you're trying to parse this using EMF.
Is that the case?
> <trans>
> <tran>
> <name>XXX</name>
> <src/> <tran>
> </trans>
Ed Merks
Previous Topic:Juno Fails to Connect to Market
Next Topic:Creating Dynamic Web Project not running.
Current Time: Fri May 27 20:17:51 GMT 2022
Powered by FUDForum. Page generated in 0.02783 seconds
