Home » Modeling » TMF (Xtext) » How can I setup xtend-maven-plugin encode for Xtend2 generation?
How can I setup xtend-maven-plugin encode for Xtend2 generation? [message #902488] Fri, 17 August 2012 21:35 Go to next message
Cristiano Gavião is currently offline Cristiano GaviãoFriend
I have a test class defined in Xtend and using utf-8.
One of the sentence is this:
		assertEquals(person1.lastName, "Gavião")
That is being translated to this:
    Assert.assertEquals(_lastName, "Gavi\u00E3o");
Well, at test execution I'm getting a error for this assert:
org.junit.ComparisonFailure: expected:<Gavi[√£]o> but was:<Gavi[ã]o>
	at org.junit.Assert.assertEquals(Assert.java:125)
Could someone explain me how can I setup xtend-maven-plugin to use utf-8 ?
thanks.
Cristiano
Re: How can I setup xtend-maven-plugin encode for Xtend2 generation? [message #902492 is a reply to message #902488] Fri, 17 August 2012 22:16 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
Hi setting the property encoding in the configuration of the plugin doesnt work?
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: How can I setup xtend-maven-plugin encode for Xtend2 generation? [message #902572 is a reply to message #902492] Sat, 18 August 2012 14:02 Go to previous message
Problem solved...
The culprit was in tycho-surefire-plugin setup. after I have add appArgLine configuration in the root POM, things starts to work:
<pluginManagement>
    <plugin>
                    <groupId>org.eclipse.tycho</groupId>
                    <artifactId>tycho-surefire-plugin</artifactId>
                    <version>${tycho-version}</version>
                    <configuration>
                        <appArgLine>-Dfile.encoding=UTF-8</appArgLine>
                    </configuration>
 </plugin>
Now my xtext projects and xtend tests are running well with tycho 0.15.
regards,
Cristiano
Previous Topic:Formatter indentation Increment/Decrement
Next Topic:handle editor crashes on opening
Current Time: Sun Sep 20 17:26:30 GMT 2020
Powered by FUDForum. Page generated in 0.01673 seconds
