Home » Modeling » TMF (Xtext) » How do you extract DSL out of Java objects?(How do you extract DSL out of Java objects?)
How do you extract DSL out of Java objects? [message #902480] Fri, 17 August 2012 20:38 Go to next message
Reo Dreams is currently offline Reo DreamsFriend
Let's say I have the following Java class Student with a pair of getter/setter methods:
public class Student
int age;
public int getAge()
return age;
public void setAge(int newAge)
age = newAge;
How do I automatically create a vocabulary for the above class, i.e. a DSL that represents the getter/setter as shown below:
* set the age of Student to "{value}"
* the age of Student
Can this even be done using XTest?
Reo.
Re: How do you extract DSL out of Java objects? [message #902483 is a reply to message #902480] Fri, 17 August 2012 21:09 Go to previous message
Christian Dietrich is currently offline Christian DietrichFriend
yes Xtext has support for Jvm Types. the thing that is problematic
(for code completion) is your synatax that names the getter/setter first and then then Class.
Here is a (syntactically and funtionally)simplified example
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl "http://www.xtext.org/example/mydsl/MyDsl"
import "http://www.eclipse.org/xtext/common/JavaVMTypes" as types
Model:
	statements += Statement*;
Statement:
	SetStatement | GetStatement
GetStatement:
	"with" class=[types::JvmDeclaredType|FQN] "get" "the" op=[types::JvmOperation]
SetStatement:
	"with" class=[types::JvmDeclaredType|FQN] "set" "the" op=[types::JvmOperation] "to" value=STRING
FQN: ID ("." ID)*;
public class MyDslScopeProvider extends AbstractDeclarativeScopeProvider {
	IScope scope_Statement_op(SetStatement context, EReference ref) {
		Iterable<JvmOperation> setters = Iterables.filter(context.getClass_().getDeclaredOperations(), new Predicate<JvmOperation>() {
			public boolean apply(JvmOperation op) {
				return op.getSimpleName().startsWith("set") && op.getParameters().size() == 1;
		Function<JvmOperation, QualifiedName> nameComputation = new Function<JvmOperation, QualifiedName>() {
			public QualifiedName apply(JvmOperation op) {
				return QualifiedName.create(op.getSimpleName().substring(3).toLowerCase());
		return Scopes.scopeFor(setters, nameComputation , IScope.NULLSCOPE);
	IScope scope_Statement_op(GetStatement context, EReference ref) {
				return op.getSimpleName().startsWith("get") && op.getParameters().size() == 0;
there are already some projects around similar languages (Cucumber/Jnario)
~Christian
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/xtext/
Twitter : @chrdietrich
Previous Topic:Shift-reduce conflict between grammar rule and terminal in Xtext
Next Topic:How @Inject ParseHelper<> is supposed to work ?
Current Time: Mon Mar 30 09:58:19 GMT 2020
Powered by FUDForum. Page generated in 0.01639 seconds
