Stereotype generalisation producing exceptions [message #902467] |
Fri, 17 August 2012 18:27 |
Luís de Sousa Messages: 214 Registered: July 2009 |
Dear all,
I'm trying to use inheritance in a profile, two stereotypes share a number of properties and hence I created an abstract steretype which they generalise. The picture attached shows this scheme.
I can apply these stereotypes in a class diagram, but I can't set the value of the properties. When I click in the expand triangle besides the stereotype in the Properties view I get the exceptions below and no properties are ever presented. I'm also unable to save a diagram where one of these stereotypes are used.
Is this schema compliant with the standard? (I believe so) Or should stereotype generalisation be declared a different way?
Thank you for reading.
eclipse.buildId=M20110909-1335
java.version=1.6.0_26
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os linux -ws gtk -arch x86 -product org.eclipse.epp.package.java.product
Error
Fri Aug 17 20:12:47 CEST 2012
Unhandled event loop exception
at org.eclipse.emf.ecore.impl.EStructuralFeatureImpl.getSettingDelegate(EStructuralFeatureImpl.java:836)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSettingDelegate(BasicEObjectImpl.java:1571)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1037)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1021)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1013)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1008)
at org.eclipse.uml2.uml.internal.operations.ElementOperations.getValue(ElementOperations.java:604)
at org.eclipse.uml2.uml.internal.impl.ElementImpl.getValue(ElementImpl.java:296)
at org.eclipse.papyrus.profile.tree.objects.AppliedStereotypePropertyTreeObject.getValue(AppliedStereotypePropertyTreeObject.java:119)
at org.eclipse.papyrus.profile.tree.objects.AppliedStereotypePropertyTreeObject.createChildren(AppliedStereotypePropertyTreeObject.java:87)
at org.eclipse.papyrus.profile.tree.objects.ParentTreeObject.getChildren(ParentTreeObject.java:114)
at org.eclipse.papyrus.profile.tree.ProfileElementContentProvider.hasChildren(ProfileElementContentProvider.java:121)
at org.eclipse.jface.viewers.AbstractTreeViewer.isExpandable(AbstractTreeViewer.java:2127)
at org.eclipse.jface.viewers.TreeViewer.isExpandable(TreeViewer.java:588)
at org.eclipse.jface.viewers.AbstractTreeViewer.isExpandable(AbstractTreeViewer.java:2153)
at org.eclipse.jface.viewers.AbstractTreeViewer.updatePlus(AbstractTreeViewer.java:2835)
at org.eclipse.jface.viewers.TreeViewer.updatePlus(TreeViewer.java:852)
at org.eclipse.jface.viewers.AbstractTreeViewer.createTreeItem(AbstractTreeViewer.java:834)
at org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractTreeViewer.java:808)
at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren(AbstractTreeViewer.java:782)
at org.eclipse.jface.viewers.TreeViewer.createChildren(TreeViewer.java:644)
at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren(AbstractTreeViewer.java:753)
at org.eclipse.jface.viewers.AbstractTreeViewer.handleTreeExpand(AbstractTreeViewer.java:1485)
at org.eclipse.jface.viewers.TreeViewer.handleTreeExpand(TreeViewer.java:952)
at org.eclipse.jface.viewers.AbstractTreeViewer$4.treeExpanded(AbstractTreeViewer.java:1496)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:132)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1258)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1282)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1267)
at org.eclipse.swt.widgets.Tree.gtk_test_expand_row(Tree.java:2130)
at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:1775)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4414)
at org.eclipse.swt.internal.gtk.OS._gtk_main_do_event(Native Method)
at org.eclipse.swt.internal.gtk.OS.gtk_main_do_event(OS.java:8422)
at org.eclipse.swt.widgets.Display.eventProc(Display.java:1245)
at org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(Native Method)
at org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(OS.java:2276)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3207)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Error
Problems occurred when invoking code from plug-in: "org.eclipse.jface".
at org.eclipse.papyrus.profile.tree.ProfileElementLabelProvider.getText(ProfileElementLabelProvider.java:127)
at org.eclipse.jface.viewers.WrappedViewerLabelProvider.getText(WrappedViewerLabelProvider.java:108)
at org.eclipse.jface.viewers.WrappedViewerLabelProvider.update(WrappedViewerLabelProvider.java:164)
at org.eclipse.jface.viewers.ViewerColumn.refresh(ViewerColumn.java:152)
at org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(AbstractTreeViewer.java:938)
at org.eclipse.jface.viewers.AbstractTreeViewer$UpdateItemSafeRunnable.run(AbstractTreeViewer.java:106)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(AbstractTreeViewer.java:1018)
at org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRunnable.run(StructuredViewer.java:485)
at org.eclipse.jface.viewers.StructuredViewer.updateItem(StructuredViewer.java:2167)
at org.eclipse.jface.viewers.AbstractTreeViewer.createTreeItem(AbstractTreeViewer.java:833)
[Updated on: Fri, 17 August 2012 18:28] Report message to a moderator
FUDForum. Page generated in 0.02685 seconds
