Home » Modeling » EMF » [CDO/DAWN] Missing Constraints while trying to reproduce "Getting Started With Dawn Web&
[CDO/DAWN] Missing Constraints while trying to reproduce "Getting Started With Dawn Web& [message #902404] |
Fri, 17 August 2012 13:46 |
Juan Pedro Silva Messages: 258 Registered: July 2009 |
Hi everybody.
I'm trying to follow the steps in this Dawn Web tutorial.
So far, I have installed all required software (including the external
dependencies), and checkout the sources from the CDO Incubation GIT
repository. The projects build correctly, as all dependencies are satisfied.
I change the cdo-server.xml as required, and run the CDO server. It
starts with no error reports. However, when I try to run the
"DawnHTTPServer.launch", I get a Validation pop-up reporting some
Missing Constraints. In particular, it reports on:
org.eclipse.emf.cdo.dawn.util;bundle-version="[1.0.0,3.0.0)", ->
org.eclipse.emf.cdo.dawn.util 1.0.0.v20110516-1727 installed
org.eclipse.emf.cdo;bundle-version="[4.0.0,5.0.0)",
-> org.eclipse.emf.cdo 4.0.1.v20120214-1021 installed
org.eclipse.emf.cdo.dawn.examples.acore;bundle-version="[1.0.0,2.0.0)",
-> org.eclipse.emf.cdo.dawn.examples.acore 1.0.0.v20110516-1727 installed
org.prototypejs;bundle-version="[1.6.0,2.0.0)"
-> org.prototypejs 1.6.1.201102051638 installed
org.draw2d;bundle-version="0.9.14"
-> org.draw2d 0.9.14.201102051638 installed
Is not a problem of the plugin versions, as I changed the manifest to
take any version, and the problem persisted. The workbench is able to
find the plugins, as it reports no unfulfilled dependencies. I believe
the problem may be the web server not knowing where to look.
The log states:
Command-line arguments: -dev
file:SomePath/dawn_wkspc/.metadata/.plugins/org.eclipse.pde.core/DawnHTTPServer/dev.properties
-os win32 -ws win32 -arch x86 -console
but the DawnHTTPServer folder doesn't exist in
/.metadata/.plugins/org.eclipse.pde.core/, although I'm not really sure
that it is related.
Could you give me some pointers on how to solve this issue?
Thanks in advance.
JP
Re: [CDO/DAWN] Missing Constraints while trying to reproduce "Getting Started With Dawn Web [message #902675 is a reply to message #902404] |
Sun, 19 August 2012 09:52 |
Martin Fluegge Messages: 141 Registered: July 2009 |
Hi Juan,
Currently I am on the road and I can't check it myself. I'll try to do
this tomorrow. Meanwhile please check whether there are some missing
requirements from the dawn bundle.
Could you please hit the "validate bundles" button in the lauch config
and check whether something else is missing?
Mart
Am 17.08.2012 15:46, schrieb Juan Pedro Silva Gallino:
> Hi everybody.
> satisfied.
> The log states:
> that it is related.
> Thanks in advance.
> Regards,
> JP
Re: [CDO/DAWN] Missing Constraints while trying to reproduce "Getting Started With Dawn Web [message #902677 is a reply to message #902675] |
Sun, 19 August 2012 12:26 |
Martin, thanks for your answer.
I followed your suggestion, and while I was there (in the launch
configuration) I realized that the missing bundles were not selected
among the ones in the target platform. Selecting them there solved the
issue.
Thanks again for your help.
Juan Pedro
El 19/08/2012 11:52, Martin Flügge escribió:
> Hi Juan,
> Cheers,
> Mart
>> Hi everybody.
>> satisfied.
>> The log states:
>> that it is related.
>> Thanks in advance.
>> Regards,
>> JP
Current Time: Thu Apr 25 06:29:41 GMT 2024
Powered by FUDForum. Page generated in 0.03119 seconds
