Parsing Ambiguity Problem [message #902351] |
Fri, 17 August 2012 09:05 |
Johan Eker Messages: 6 Registered: August 2012 |
Hi All,
I have parsing issue which I fail to resolve and kindly ask for a little bit of help. I have put together a small sample language that demonstrates problem. The problem I have is to distinguish between a float expression (e.g. "3.14") and a list expression (e.g. "1..4" that represents the integer list [1,2,3,4]). The problem that I fail to get the generated xtext parser to accept the list expression unless additional white space is inserted, i.e. "1 ..4" works while "1..4" failes.
The fact that the float is a terminal and the list is a production might have something to do my headache.
The sample language consist of variable declarations and expressions:
A = 3.14 // Real valued variable with initial value
B = 3+4 // Integer valued variable with initial value
C = 1..4 // List valued variable with initial value consisting of the integer lists [1,2,3,4]
D = X.d + Y.a // We also support field accesses in expression
// (although in the sample language there is now way to actually define fields:-)
The grammar is as follows:
--------------------------8<--------------------------------
grammar org.xtext.example.mydsl.TestLang with org.eclipse.xtext.common.Terminals
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
generate testLang "<URL removed due to forum restrictions on newbies>"
Namespace:
'namespace' name = ID ':'
( variables += Variable) *
'end';
Variable: name = ID '=' value = Expression ';';
Expression:
ExpressionSimple ({Expression.left=current} operator=('+' | '-' | '..') right=ExpressionSimple)?;
ExpressionSimple:
ExpressionInteger | ExpressionFloat | ExpressionOctal | ExpressionVariable ;
ExpressionInteger: value=DECIMAL;
ExpressionOctal: value=OCTAL;
terminal DECIMAL returns ecore::ELong : ('1'..'9') ('0'..'9')*;
terminal OCTAL returns ecore::ELong : '0' ('0'..'7')*;
ExpressionVariable: value=[Variable] ('.' fields+=ID)*;
ExpressionFloat: value=FLOAT;
terminal FLOAT returns ecore::EFloat :
('0'..'9')+ '.' ('0'..'9')* (('e'|'E') ('+' | '-')? ('0'..'9')+)?
| '.' ('0'..'9')+ (('e'|'E') ('+' | '-')? ('0'..'9')+)?
| ('0'..'9')+ ('e'|'E') ('+' | '-')? ('0'..'9')+;
So now the problem. Considers the follow program it fails to parse the list expression that initializes variable B4. The reason seems to be a conflict with the float terminal.
namespace NS1:
B1 = 2;
B2 = B1..1;
B3 = 1 + 1;
X = 1;
Y = 1.1;
Z = X.a.b;
B4 = 1..1; // <--gives error
B5 = 1 ..1;
B6 = B1.a..2;
B7 = B1.a.b..B2.a.d;
end
Any insight into solving this problem is greatly appreciated.
Johan
FUDForum. Page generated in 0.04381 seconds
