Home » Eclipse Projects » WindowBuilder » How add restriction to delete a component
Re: How add restriction to delete a component [message #902273 is a reply to message #902270] |
Thu, 16 August 2012 17:41 |
Konstantin Scheglov Messages: 555 Registered: July 2009 |
IIRC "isComponentType" is available only for flow/simple containers.
And if there is any error in "canDelete" script, we consider this as "false".
In other scripts you have only ReflectionUtils class.
But actually all this can be done using ReflectionUtils, see org.eclipse.wb.internal.core.model.generic.ContainerObjectValidators.DEF_functions
private static final String DEF_functions = StringUtils.join(new String[]{
"def isModelType(model, c) {",
" if (c is String) {",
" return ReflectionUtils.isSuccessorOf((Class) model.description.componentClass, c);",
" } else {",
" return c.isAssignableFrom(model.description.componentClass);",
"def isSuccessorOf(o, c) {",
" return ReflectionUtils.isSuccessorOf(o, c);",
" } else {",
" return o != null && c.isAssignableFrom(o.getClass());",
"def isComponentType(c) {",
" return isModelType(component, c);",
"def isReferenceType(c) {",
" return isModelType(reference, c);",
"def isContainerType(c) {",
" return isModelType(container, c);",
"def isContainerThis() {",
" return isSuccessorOf(container.creationSupport, "
+ "'org.eclipse.wb.internal.core.model.creation.ThisCreationSupport');",
"};",}, "\n");
Konstantin Scheglov,
Google, Inc.
[Updated on: Thu, 16 August 2012 17:41] Report message to a moderator
Current Time: Wed Apr 17 22:18:34 GMT 2024
Powered by FUDForum. Page generated in 0.03320 seconds
