Home » Modeling » EMF » EMF with BeanSupport?(how to add an adapter which transforms notifications to pcs...)
EMF with BeanSupport? [message #902135] Thu, 16 August 2012 06:16 Go to next message
Ludwig Moser is currently offline Ludwig MoserFriend
Hi!
i do need java bean support on my model for a component with glazedlists (which does only support javabeans and not emf)
my attempt was to create a class in EMF which is called JavaBeanSupport.
it provides simple functions like
  • propertyChange
  • addPropertyChangeListener
  • removePropertyChangeListener
any EClass in my model which extends this JavaBeanSupport should act as a bean...
so far so good.
i register an adapter on the class so i get an notification for every change.
in this adapter i create an PropertyChangeEvent from the notification and then send the propertyChange
but i have the problem that i cannot gain the name of the property that changed.
how can i do this?
String propertyName = n.getClass().getSimpleName() + "."
					+ n.getEventType();
i need to transform the eventtype to the property name string
PropertyChangeEvent evt = new PropertyChangeEvent(n.getNotifier(), "propertyName", getOldValue(), n.getNewValue());
// notify.getNotifier() or better notify.getFeature()?
PS: or is there already a solution to my problem? (though i did not find one on google nor this forum)
Re: EMF with BeanSupport? [message #902148 is a reply to message #902135] Thu, 16 August 2012 06:49 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
A change notification passes the EStructureFeature so this the name.
Tom
Am 16.08.12 08:16, schrieb Ludwig Moser:
> Hi!
> propertyChange
> a bean...
> so far so good.
> change.
> changed.
> how can i do this?
> + n.getEventType();
Re: EMF with BeanSupport? [message #902150 is a reply to message #902135] Thu, 16 August 2012 07:01 Go to previous messageGo to next message
Ludwig,
Notification.getFeature for notifications from EObjects should return
you the EStrucutralFeature (except for the REMOVING_ADAPTER event) and
from that you can get the name.
Rather than modeling JavaBeanSupport as an EClass, you might extend
EObjectImpl or MinimalEObjectImpl and specify your extension as the Root
Extends Class of the GenModel to use it for all your implementation
classes. You can specify a Root Extends Interface if you want something
in all your generated interfaces...
On 16/08/2012 8:16 AM, Ludwig Moser wrote:
> Hi!
> propertyChange
> as a bean...
> so far so good.
> change.
> that changed.
> how can i do this?
> + n.getEventType();
Ed Merks
Re: EMF with BeanSupport? [message #902151 is a reply to message #902148] Thu, 16 August 2012 07:04 Go to previous messageGo to next message
thanks tom!
EAttribute attr = (EAttribute) n.getFeature();
String propertyName = attr.getName();
Re: EMF with BeanSupport? [message #902152 is a reply to message #902151] Thu, 16 August 2012 07:11 Go to previous messageGo to next message
i will try the root element too, thanks ed!
Re: EMF with BeanSupport? [message #902155 is a reply to message #902151] Thu, 16 August 2012 07:20 Go to previous messageGo to next message
Ludwig,
Keep in mind that EReferences produce notifications as well, so better
to cast to EStructuralFeature. And be careful that it will be null for
REMOVING_ADAPTER.
On 16/08/2012 9:04 AM, Ludwig Moser wrote:
> thanks tom!
Ed Merks
Re: EMF with BeanSupport? [message #902202 is a reply to message #902155] Thu, 16 August 2012 10:30 Go to previous messageGo to next message
so how can i transform a sturcturalfeature to a string like
MyObject.Address.street
where MyObject is my Class, Address is my reference and street is the attribute...
because i need to resolve this then...
Re: EMF with BeanSupport? [message #902209 is a reply to message #902202] Thu, 16 August 2012 11:28 Go to previous messageGo to next message
Ludwig,
You can use EStructuralFeature.getEContainingClass the containing
class. I'm not sure if you want the class that defines the feature of
if you want the actual class of the EObject (i.e., EObject.eClass(). I
don't understand the three part name. What do you mean by Address is
the reference? An EReference?
> Quote:
> attribute...
Ed Merks
Re: EMF with BeanSupport? [message #902716 is a reply to message #902209] Mon, 20 August 2012 05:39 Go to previous messageGo to next message
let me explain it by a small example
we have ECLasses Person & Address
where Person has Attributes name, adress (an EReference to EClass Address), etc
where Address has Attributes street, city, country
get an notification from an instance of Eclass Person
and i need to access the attribute street of this person...
i usualy do this with an FeaturePath
FeaturePath.fromList(eStructuralFeatureGetAddress, eStructuralFeatureGetStreet)
by using this featurePath i could create the String (which java beans uses to resolve the getter&setter)
btw: the string would be: address.street (which gets resolved to getAddress().getStreet())
how can i do this with only one structuralfeature from the notification?
i hope you understand now what i need, or what my problem is.
thanks for your patience Smile
Re: EMF with BeanSupport? [message #902720 is a reply to message #902716] Mon, 20 August 2012 06:49 Go to previous messageGo to next message
Ludwig,
Comments below.
> Address), etc
For the purpose of producing a bean notification. I would have imagined
that only the Address bean produces notifications for changes to the
street, which is a property of Address not a property of Person.
Person will only get notifications for changes to its own features.
No, I just have more questions. Isn't it the case that beans produce
notifications only for changes to their own properties? After all, the
Address bean doesn't know which Person bean refers to it; it might even
be shared among many persons (and you've not mentioned whether it's a
containment reference, which would imply it's only referenced by one
Person).
> thanks for your patience :)
Ed Merks
Re: EMF with BeanSupport? [message #902757 is a reply to message #902720] Mon, 20 August 2012 09:44 Go to previous messageGo to next message
you are right notifications for any change in an attribute is only needed the object which contains it.
its true that there might be an situation which makes differences if its a containment or not.
in my case its 'only' for glazedlists, which do not support EMF.
i do bind some objects to my table then the
lists register for property-changes on the properties i display in my table.
if any of the bound data changes, i fire the correlating property change event;
(if the event is not registered by the list it gets dropped, otherwise the table updates the cell which got changed)
btw: this is my current adapter
Adapter adapter = new AdapterImpl() {
		public void notifyChanged(Notification n) {
			EStructuralFeature feature = (EStructuralFeature) n.getFeature();
			if (feature == null) {
				return;
					feature.getName(), n.getOldValue(), n.getNewValue());
do you think the way i do it is incorrect?
Re: EMF with BeanSupport? [message #902833 is a reply to message #902757] Mon, 20 August 2012 16:56 Go to previous message
Ludwig,
Comments below.
That will affect whether objects are shared. A containment reference
guarantees that the object is contained in at most one place no matter
how much you might try to share it; EMF will automatically remove it
from another container.
> table.
> change event;
> n.getFeature();
> return;
> n.getNewValue()); }
I don't know enough about PropertyChangeEvent to say if this is
correct. OldValue and NewValue mean different things depending on the
type of Notification event...
Ed Merks
Previous Topic:[CDO/DAWN] Missing Constraints while trying to reproduce "Getting Started With Dawn Web&
Next Topic:Xcore is really awesome.
Current Time: Wed Mar 03 03:55:19 GMT 2021
Powered by FUDForum. Page generated in 0.02009 seconds
