Home » Modeling » M2T (model-to-text transformation) » Meshing ACCELEO and Xtext
Meshing ACCELEO and Xtext [message #901948] Wed, 15 August 2012 09:08 Go to next message
Andrea Sindico is currently offline Andrea SindicoFriend
I am in the middle of an ACCELEO Transformation aimed at producing code (i.e. Java) from an input UML model.
Some elements of this UML model (i.e. Activities Opaque actions) contain some text which is conform to an Xtext grammar and I'd like to get the equivalent AST Ecore representation in the ACCELEO transformation.
To this end I have developed a Java class with a method which takes as input a string, containing the DSL excerpt, and produces an ECORE model conform to it (see http://www.eclipse.org/forums/index.php/m/901947/#msg_901947 for further details). I have tested it in a separate Java application and it seems it works properly.
I have therefore written a simple ACCELEO module (i.e. getDSLModel) wrapping that java class and enabling me to get the Ecore model from the DSL textual representation.
Suppose my DSL (and the equivalent ECORE) consist of a root element named DSLModel containing a (0..*) number of DSLStatements (this is a simplification).
When in ACCELEO I invoke the wrapper from a string, containing a correct dsl script, i have noticed it correctly returns a ModelImpl
['statement1;statement2'.getDSLModel()/]
so the Java service and the XText parse is working.
However if I try to get the model statements, i.e.:
['statement1;statement2'.getDSLModel().statements/]
it returns an **"invalid"** string. So I can't use it in a for loop
I have therefore tried to call the eAllContents() ocl service from the model instance i.e.:
['statement1;statement2'.getDSLModel().eAllContents()/]
and it actually returns the list of statements. I do not understand why the features of the Ecore entities returned from the Xtext parser are not working properly.
Any help would be very appreciated! Thank you
here is the Java service which turns a string into a instance of my DSL model (ECORE AST). I have tested it with an independent Java application and it works fine!
     public class GetDSLModel {
	 public DSLModel getDSLModel(String expression){
		DSLStandaloneSetupGenerated dslsas = new DSLStandaloneSetupGenerated();
		Injector injector = dslsas.createInjectorAndDoEMFRegistration();
		XtextResourceSet resourceSet = injector.getInstance(XtextResourceSet.class);
		resourceSet.addLoadOption(XtextResource.OPTION_RESOLVE_ALL, Boolean.TRUE);
		Resource resource = resourceSet.createResource(URI.createURI("dummy:/example.dsl"));
		InputStream in = new ByteArrayInputStream(expression.getBytes());
		try {
			resource.load(in, resourceSet.getLoadOptions());
			DSLModel model = (DSLModel) resource.getContents().get(0);
			return model;
		} catch (IOException e) {
			e.printStackTrace();
		return null;
Now I need the AST in the main ACCELEO (UML2Text) transformation thus here is the Acceleo wrapper
     [query public getDSLModel(str:String): DSLModel =  (invoke('sfg.baleno.src.mloaders.GetDSLModel','getDSLModel(java.lang.String)',Sequence{str})).oclAsType(DSLModel)/]
here is what I get if run it
      input: ['statement1;statement2'.getDSLModel()/]
      output: mypackage.dsl.impl.DSLModelImpl@a1c7a
      input: ['statement1;statement2'.getDSLModel().statements/]  (Syntactically VALID)
      output: invalid
      input: ['statement1;statement2'.getDSLModel().eAllContents()/]
      output: mypackage.dsl.impl.DSLStatement@e53202 (......
Follow me on Twitter @andreasindico
[Updated on: Wed, 15 August 2012 16:15]
Report message to a moderator
Re: Meshing ACCELEO and Xtext [message #901963 is a reply to message #901948] Wed, 15 August 2012 10:39 Go to previous messageGo to next message
It certainly can work, but your details are a little vague so it's
difficult to help.
You could debug why the invalid is created, or perhaps just do a resolve
all proxies before starting and check for deep errors (errors in any
Resource.errors).
Ed Willink
> transformation.
> further details)
> I have therefore written a simple ACCELEO module wrapping that java
> representation.
> named MODEL containing a (0..*) number of STATEMENTs (this is a
> simplification). When in ACCELEO I invoke the wrapper from a string i
> have noticed it correctly returns a ModelImpl so the Java service and
> the XText parse is working. However if I try to get the model
> statements it returns an "invalid" strings. I have therefore tried to
> call the eAllContents() ocl service from the model instance and it
> working properly.
Re: Meshing ACCELEO and Xtext [message #902029 is a reply to message #901963] Wed, 15 August 2012 14:40 Go to previous messageGo to next message
Hi Ed, thank you for your answer. What do you mean with "just do a resolve all proxies before starting" I admit I didn't get it Sad
Re: Meshing ACCELEO and Xtext [message #902051 is a reply to message #902029] Wed, 15 August 2012 16:24 Go to previous messageGo to next message
Ed I have have added more details to my question. I hope it helps to understand what is not working. It seems the problem relates to the passage of a meta-model element implementation to its ACCELEO representation but I am actually not that sure. It is a bit frustrating as I was very close to my aim, I thought the hardest part was the on the fly transformation of a string into a model Smile
Re: Meshing ACCELEO and Xtext [message #902072 is a reply to message #902029] Wed, 15 August 2012 18:04 Go to previous messageGo to next message
> resolve all proxies before starting" I admit I didn't get it :(
EcoreUtil.resolveAll()
Re: Meshing ACCELEO and Xtext [message #902084 is a reply to message #902072] Wed, 15 August 2012 19:01 Go to previous messageGo to next message
Ok I have changed the Java service this way:
		EcoreUtil.resolveAll(resourceSet);
		try {
			EcoreUtil.resolveAll(model);
                        return model;
		return null;
It still works when invoked from another Java class but it still outputs invalid in Acceleo
Re: Meshing ACCELEO and Xtext [message #902092 is a reply to message #902084] Wed, 15 August 2012 19:25 Go to previous messageGo to next message
Why don't you call DSLStandaloneSetup.doSetup() ?
Ed Willink
> Boolean.TRUE);
> Resource resource =
> try {
> return model;
> return null;
Re: Meshing ACCELEO and Xtext [message #902111 is a reply to message #902092] Wed, 15 August 2012 22:02 Go to previous messageGo to next message
Ok now the Java code looks like this
                DSLStandaloneSetup.doSetup();
		try {
                        return model;
		return null;
unfortunally it behaves the same. It works when executed from another java class but "it doesn't" when invoked from Acceleo
Re: Meshing ACCELEO and Xtext [message #902122 is a reply to message #902111] Thu, 16 August 2012 04:39 Go to previous messageGo to next message
DSLStandaloneSetup.doSetup() is all that you need and you just put it
where the comments in Acceleo say to register your packages.
Ed Willink
> Boolean.TRUE);
> Resource resource =
> try {
> return model;
> return null;
Re: Meshing ACCELEO and Xtext [message #902130 is a reply to message #902122] Thu, 16 August 2012 05:47 Go to previous messageGo to next message
Hi Ed, where are those comments in Acceleo? And how should I invoke the StandaloneSetup.doSetup() in Acceleo, by means of a different wrapper?
Anyway I have also tried to rearrange the code this way:
		ResourceSet resourceSet = new ResourceSetImpl();
		try {
                        return model;
		return null;
different code same behavior. It works fine when invoked from a different java class but when invoked from Acceleo, though I see it returns correct ClassImpl instances they are apparently not properly turned into the equivalent ECORE entities.
thank you for your kind help
[Updated on: Thu, 16 August 2012 05:49]
Re: Meshing ACCELEO and Xtext [message #902139 is a reply to message #902130] Thu, 16 August 2012 06:16 Go to previous messageGo to next message
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
<div class="moz-cite-prefix">Hi<br>
<br>
You provide one erroneous class and expect help.<br>
<br>
I've no idea what it does, but it seems all wrong so just delete
it. Why would you  expect your ResourceSet to coexist with
Acceleo's and Xtext's?<br>
<br>
Acceleo generates a Java file for your main template. That file is
full of comments about how to make it work standalone. Try reading
them.<br>
<br>
From the Acceleo documentation:<br>
<br>
<h3>Package registration</h3>
<p> You need to register the package that contains your
classifiers, in order to use it inside of your generator. To do
this, have a look at the method named "registerPackages" in the
Java launcher generated next to your main module. You need to
add the following piece of code: </p>
<pre> /**
* @generated NOT
public void registerPackages(ResourceSet resourceSet) {
super.registerPackages(resourceSet);
if (!isInWorkspace(MyPackage.class)) {
resourceSet.getPackageRegistry().put(MyPackage.eINSTANCE.getNsURI(), MyPackage.eINSTANCE);
</pre>
<p> The "@generated NOT" tag in the Javadoc is necessary to
prevent the removal of your modification. Once the package is
registered, Acceleo can use EMF to load your input model. If
this does not work, you will see an error message stating that
EMF cannot find the package with the uri "<metamodel_uri>". </metamodel_uri></p>
This is where you can put DSLStandaloneSetup.doSetup();<br>
<br>
If you're paranoid about double initialization you can do:<br>
<br>
    @Override<br>
    public void initialize(EObject element, File folder, List&lt;?
extends Object&gt; arguments) throws IOException {<br>
        preInitialize();<br>
        super.initialize(element, folder, arguments);<br>
    }<br>
<br>
    @Override<br>
    public void initialize(URI modelURI, File folder,
List&lt;?&gt; arguments) throws IOException {<br>
        super.initialize(modelURI, folder, arguments);<br>
    }<br>
<br>
    protected void preInitialize() {<br>
    }<br>
<br>
or<br>
<br>
    static {<br>
        if (!EMFPlugin.IS_ECLIPSE_RUNNING) {<br>
        }<br>
    }<br>
<br>
    Regards<br>
<br>
        Ed Willink<br>
<br>
On 16/08/2012 06:47, Andrea Sindico wrote:<br>
</div>
<blockquote cite="mid:k0i1i2$iv5$1@xxxxxxxxe.org" type="cite">Hi
wrapper?
<br>
<br>
<br>
<br>
<br>
<br>
               DSLStandaloneSetup.doSetup();    <br>
<br>
Boolean.TRUE);
<br>
<br>
               Resource resource =
<br>
<br>
        try {
<br>
<br>
<br>
<br>
                       return model;
<br>
<br>
<br>
<br>
<br>
        return null;
<br>
        <br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
<br>
</body>
</html>
Re: Meshing ACCELEO and Xtext [message #902173 is a reply to message #902139] Thu, 16 August 2012 08:43 Go to previous messageGo to next message
Ed I have added these lines to the Acceleo main module Java class:
    public void initialize(EObject element, File folder, java.util.List<? extends Object> arguments) throws IOException {    preInitialize();
    public void initialize(URI modelURI, File folder, java.util.List<?> arguments) throws IOException {
        preInitialize();
and
       if (!isInWorkspace(org.eclipse.uml2.uml.UMLPackage.class)) {
            resourceSet.getPackageRegistry().put(org.eclipse.uml2.uml.UMLPackage.eINSTANCE.getNsURI(), org.eclipse.uml2.uml.UMLPackage.eINSTANCE);
        if (!isInWorkspace(mypackages.DSLPackage.class)) {
            resourceSet.getPackageRegistry().put(mypackages.DSLPackage.eINSTANCE.getNsURI(), mypackages.DSLPackage.eINSTANCE);
but I still experience the same problem.
I have however noticed something new that I guess may help to understand the problem.
If I try this let:
[let dm:DSLModel = 'statement1;statement2;'.getDSLModel().oclAsType(DSLModel)]
I get this warning:
Undefined "Let" expression at line xx in Module ww for block let dm : DSLModel = getDSLModel('statement1;statement2').oclAsType(dsl::DSLModel). Last recorded value of self was org.eclipse.uml2.uml.internal.impl.ClassImpl@96f20a
Re: Meshing ACCELEO and Xtext [message #902176 is a reply to message #902173] Thu, 16 August 2012 08:48 Go to previous messageGo to next message
The error means that
evaluated to invalid so you can debug that with a breakpoint in
getDSLModel().
Ed Willink
> @Override
> preInitialize();
> @Override
> preInitialize();
> and
> @Override
> understand the problem. If I try this let:
> [let dm:DSLModel =
> I get this warning:
> DSLModel =
> mailto:org.eclipse.uml2.uml.internal.impl.ClassImpl@96f20a
Re: Meshing ACCELEO and Xtext [message #902177 is a reply to message #902176] Thu, 16 August 2012 08:56 Go to previous messageGo to next message
I did it and it seems there are no problems. Moreover if a run it,exactly the same class and not a copy, from an independent Java class it actually returns a valid AST of the input string.
Re: Meshing ACCELEO and Xtext [message #902178 is a reply to message #902177] Thu, 16 August 2012 08:59 Go to previous messageGo to next message
Also if I run this
   [let dm:DSLModel = 'statement1;statement2;'.getDSLModel()]
the warning disappears (though it sill does not work)
[Updated on: Thu, 16 August 2012 09:00]
Re: Meshing ACCELEO and Xtext [message #902179 is a reply to message #902177] Thu, 16 August 2012 09:00 Go to previous messageGo to next message
Of course there is a problem. You have an error message.
An independent class is indeed independent. It has very different
initialization and that is ultimately what you need to debug.
Ed Willink
Re: Meshing ACCELEO and Xtext [message #902400 is a reply to message #901948] Fri, 17 August 2012 13:16 Go to previous messageGo to next message
May the problem be I am actually using two different resource sets (one in the Acceleo module Java class and one in the XText Java service)? If so what is the right way to make the Java service retrieve the Acceleo resource set?
Re: Meshing ACCELEO and Xtext [message #902403 is a reply to message #902400] Fri, 17 August 2012 13:41 Go to previous messageGo to next message
In my experience it's best to just ignore the Xtext ResourceSet; it
looks after injection and the Xtext bits nicely.
You are dealing with models and for that you use the Acceleo ResourceSet
; (also ignore the Acceleo meta-model ResourceSet).
What is 'the Java service'?
Ed Willink
Re: Meshing ACCELEO and Xtext [message #902452 is a reply to message #902403] Fri, 17 August 2012 16:13 Go to previous messageGo to next message
Hi Ed,
In the Acceleo terminlogy a service is a Java class implementing some "complex" operation wrapped by an acceleo module. In this case I meant the java class transforming a string with a DSL into an Ecore AST by means of XText.
To quickly if the problem was due to the resource set just to check I have added a static ReousceSet variable to the main acceleo module java class. I have therefore retrieved that from the XText java service and used that instead of instantiating a new one. Unfortunately it still behaves the same Acceleo does not seem to associate the implementation to the related ECORE.
while trying I have however noticed a weird thing I don't know if it could clarify or create more confusion. It happens that sometimes when I launch the Eclipse environment (but not every time I do that!) and run the acceleo transformation it properly manages the model elements retrieved from the Java XText service. It thus works. However as soon as I slightly change the code (i.e. add another tag) it stops working again.
Again thanks for your help
Re: Meshing ACCELEO and Xtext [message #902455 is a reply to message #902452] Fri, 17 August 2012 16:37 Go to previous message
Do not abuse Xtext; in particular multiple initialization may corrupt
registries. The Xtext ResourceSet is for Xtext only.
Writing to global registries can also cause strange behaviours.
I don't understand this service business. I've looked at Acceleo
services a couple of times and always rejected them as not suitable for
my problem.
Ed Willink
On 17/08/2012 17:13, Andrea Sindico wrote:
> Hi Ed,
> means of XText.
> again.
> Regards
Previous Topic:Acceleo meta-model as namespace
Next Topic:[Acceleo] retrieving the ResourceSet from a Java service
Current Time: Mon Aug 08 08:07:43 GMT 2022
Powered by FUDForum. Page generated in 0.02401 seconds
