Re: Deploying Xtext parser along with the code generator [message #901866 is a reply to message #901828] |
Tue, 14 August 2012 20:21 |
mcse mcse Messages: 53 Registered: August 2012 |
Member |
Hi Christian,
First of all, thanks a lot for the reply.
I have built my grammar which is ambiguity-free, and subsequently developed the code generator through xtend.
Code generator serves its purpose correctly too. Indeed, I have tested the plug-in via the plugin.xml of the *.ui package.
Here, I have created model.dsl, following the grammar, which is once saved translated into another model through the code generator.
However, I wanted to let end users do the same -- i.e., creating a model following my grammar and then translating the model into another model
To let this happen, I have attempted to export plug-ins -- via deployable plug-ins and fragments section. Then, I have tried to import these
three plug ins into another eclipse release that does not have xtext framework installed. However, this did not work. The parser imposing
the user to specify model correctly and the code generator did not work. After having imported the three plugins (dsl, dsl.tests, dsl.ui),
when I clicked the plugin.xml in the dsl.ui, the new instance of eclipse is run succesfully. However, it cannot function as editor for either grammar
and the code generator.
So, I am looking for a guide that helps me make this success.
THanks in advance.
Re: Deploying Xtext parser along with the code generator [message #901882 is a reply to message #901881] |
Tue, 14 August 2012 21:24 |
you export the plugin via
rightclick on the feature xml -> Export -> Deployable features
in the wizard you select a target dirb
make sure generate metadata rep is selected at the second tab
and hit finish
in the other eclipse goto
Help -> Install new Software -> Add -> Local (select export folder here)
select the feature (you may have to deselect categorize option if you did not create a category.xml and selected it during export)
hit finish
Twitter : @chrdietrich
Re: Deploying Xtext parser along with the code generator [message #901938 is a reply to message #901882] |
Wed, 15 August 2012 08:25 |
Member |
Hi Christian,
Thanks a lot for showing me how to export and then import what has been exported.
Once I followed what you suggested, there has appeared the following error during the import stage (i.e., through the install new software..):
An error occurred while collecting items to be installed
session context was:(profile=SDKProfile, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
Problems downloading artifact: osgi.bundle,org.eclipse.xtext.xtext.ui.examples,2.1.1.v201111141332.
File has invalid content:C:\Users\CITY-A~1\AppData\Local\Temp\signatureFile8654316798185231099.jar
Invalid content:.project
A file ".project" has been removed from the jar: C:\Users\CITY-A~1\AppData\Local\Temp\signatureFile8654316798185231099.jar
Invalid content:.settings/org.eclipse.pde.prefs
A file ".settings/org.eclipse.pde.prefs" has been removed from the jar: C:\Users\CITY-A~1\AppData\Local\Temp\signatureFile8654316798185231099.jar
Invalid content:.settings/org.eclipse.jdt.core.prefs
A file ".settings/org.eclipse.jdt.core.prefs" has been removed from the jar: C:\Users\CITY-A~1\AppData\Local\Temp\signatureFile8654316798185231099.jar
Invalid content:.settings/org.eclipse.jdt.ui.prefs
A file ".settings/org.eclipse.jdt.ui.prefs" has been removed from the jar: C:\Users\CITY-A~1\AppData\Local\Temp\signatureFile8654316798185231099.jar
Invalid content:.settings/org.eclipse.core.resources.prefs
A file ".settings/org.eclipse.core.resources.prefs" has been removed from the jar: C:\Users\CITY-A~1\AppData\Local\Temp\signatureFile8654316798185231099.jar
Invalid content:.classpath
A file ".classpath" has been removed from the jar: C:\Users\CITY-A~1\AppData\Local\Temp\signatureFile8654316798185231099.jar
Invalid content:build.properties
A file "build.properties" has been removed from the jar: C:\Users\CITY-A~1\AppData\Local\Temp\signatureFile8654316798185231099.jar
Invalid content:.settings/org.eclipse.jdt.launching.prefs
A file ".settings/org.eclipse.jdt.launching.prefs" has been removed from the jar: C:\Users\CITY-A~1\AppData\Local\Temp\signatureFile8654316798185231099.jar
Before exporting my plugins, I have also chosen from the *build* tab of the feature xml both the .project and build.properties.
So, did I do the same for the plugin xml files too that the feature manages. However, the error stays the same that occurs after I click *finish* for adding the plug-in.
Re: Deploying Xtext parser along with the code generator [message #901965 is a reply to message #901964] |
Wed, 15 August 2012 10:55 |
Member |
I use Eclipse indigo, version 3.7.0 .
I do not get any error message while exporting the feature project into a folder--export process is performed succesfully.
The export folder contains the following items: features folder, plugins folder,artifacts.jar and contents.jar .
Then, I use another eclipse installation which is again indigo being the version 3.7.0 . However, this one, unlike the former one, is free of any Xtext, and Xtend frameworks.
So, once I tried to install the plugin by choosing "install new software" from the "help", and then specifying the pat of the export folder , the installation has started without any problem. But, before it terminates, the above specified error occurred.
It might be the case the the feature.xml requires further customization, about which I genuinely do not have an idea.
Re: Deploying Xtext parser along with the code generator [message #902081 is a reply to message #902035] |
Wed, 15 August 2012 18:43 |
to your first question:
is said: i took an eclipse without Xtext installed.
it works for me even with Eclipse Classic.
=> please recheck with a clean generated Xtext project without any customizations.
maybe your xtext is broken. maybe your eclipse is broken.
which os do you use? ....
i have NO idea! sorry
to your second question: create a java main class that does your stuff (e.g. by changing the workflow to)
fragment = generator.GeneratorFragment {
generateMwe = false
generateJavaMain = true
then use the Export -> Runnable Jar File Wizard to export the code including dependenies
~Christian
FUDForum. Page generated in 0.04938 seconds
