Home » Modeling » EMF » How to force generation of Validator((without defining a constraint or an invariant))
How to force generation of Validator [message #901441] Sun, 12 August 2012 12:02 Go to next message
Christoph Keimel is currently offline Christoph KeimelFriend
is it possible to force the generation of the *.util.*Validator without defining a constraint or an invariant in the model? The purpose would be to validate simple restrictions, such as the bounds of a feature.
For example using this model:
class MyElement {
	String[1] name
I would like to do something like this:
MyElement element = MyFactory.eINSTANCE.createMyElement();
Diagnostic diagnostic = Diagnostician.INSTANCE.validate(element);
Assert.isTrue(diagnostic.getSeverity() == Diagnostic.ERROR);
Greetings
Christoph
Re: How to force generation of Validator [message #901445 is a reply to message #901441] Sun, 12 August 2012 12:57 Go to previous messageGo to next message
Christoph,
Comments below.
On 12/08/2012 2:02 PM, Christoph Keimel wrote:
> Hello,
No. An important aspect of the validator is to dispatch to all the
constraints at most once, even in the face of multiple inheritance.
EObjectValidator will enforce those. Diagnostician.INSTANCE can be used
to dispatch to whatever validator is available, either the base
EObjectValidator, or the registered generated validator.
> class MyElement {
> String[1] name
That should already work.
> Greetings
> Christoph
Re: How to force generation of Validator [message #901462 is a reply to message #901445] Sun, 12 August 2012 18:14 Go to previous message
Hi Ed
Thanks for the insight! It work's just like you say.
(And it would have all along if I hadn't gotten mixed up with all my temporary tests. Time to clean up! Wink)
Smile,
Christoph
Previous Topic:[Xcore] Imposing constraints on Xcore model
Next Topic:[Teneo] @PrePersist/PreUpdate - Hibernate Interceptors - extension manager
Current Time: Sun May 24 23:25:41 GMT 2020
Powered by FUDForum. Page generated in 0.02381 seconds
