Home » Archived » Visual Editor (VE) » setup for Eclipse forms toolkit
setup for Eclipse forms toolkit [message #119989] Mon, 06 March 2006 13:16 Go to next message
I've tried to get the forms toolkit enabled on OS X based on this
article and failed:
http://www.eclipse.org/vep/WebContent/docs/newAndNoteworthy/ 1.2-M2/
I'm not familiar in designing RCP applications but I would like to start
now together with this great looking GUI builder tool.
I felt inspired as I've seen the layouts on and read about the new
capabilities for VEP on OS X and generally.
http://www.eclipse.org/articles/Article-Forms/article.html
Could someone point me what the first steps are to get VEP and forms
toolkit together?
What kind of project I have to create? I guess it should/must be a
plugin project and within there a viewpart class has to create?
Afterwards a plugin dependency has to linked to an additional created
project with the source of org.eclipse.ui.forms ?
Sorry for my confusion, actually I'm only experienced in creating swt
applications with jface.
I guess I have to study basics first, some links and orders would be
appreciated.
Thank you in advance,
Andreas
Re: setup for Eclipse forms toolkit [message #120002 is a reply to message #119989] Mon, 06 March 2006 13:22 Go to previous messageGo to next message
For OSX shouldn't be any different than for Windows or Linux. The new
and noteworthy shows how to get the forms toolkit working.
Rich Kulp
Re: setup for Eclipse forms toolkit [message #120054 is a reply to message #120002] Tue, 07 March 2006 09:34 Go to previous message
I tried using Forms last night on OS X and everything worked as
expected. To use forms, create a new plug-in project, make sure that
you select the plug-in makes UI contributions check. When the plug-in
descriptor file opens when the wizard finishes, switch to the
Dependencies tab, and add a dependency to the org.eclipse.ui.forms
plug-in and save the file.
Then create a new Visual Class extending JFace Viewers or Editors, or
SWT Shell or Composite, and the Forms elements will show on the palette.
Hope this helps,
- Jeff
Re: setup for Eclipse forms toolkit [message #612266 is a reply to message #119989] Mon, 06 March 2006 13:22 Go to previous message
Rich Kulp
Re: setup for Eclipse forms toolkit [message #612270 is a reply to message #120002] Tue, 07 March 2006 09:34 Go to previous message
Hope this helps,
- Jeff
Previous Topic:SWT Data forms control/container?
Next Topic:newby QUESTION. Visual Editor for JFace??
Current Time: Mon Jul 07 18:41:52 EDT 2025
Powered by FUDForum. Page generated in 0.26239 seconds
