Home » Modeling » TMF (Xtext) » problem with if expression
problem with if expression [message #901211] Fri, 10 August 2012 11:02
Laigle jérôme is currently offline Laigle jérômeFriend
I'm working on a DSL but i have a problem with if and endif
Because in my dsl endif was defines obligatory
But i realise test with xtend and my test pass without endif i don't understand why
My dsl:
CompilationUnit:
instructions+=Instruction*;
Instruction:
ControleStructure|VariableDeclaration|VariableAssignment;
Ifstatement:
'if'(expressions=Expression)
then+=Instruction*
(=>'else' else+=Instruction*)?
'endif' ;
VariableAssignment:
dcl=[VariableDeclaration]'='expr=Expression;
ControleStructure:
Ifstatement;
Expression :
CompareOperator;
CompareOperator returns Expression:
ConditionalOR(( /* {Inclusion.left=current} '='|*/{Equality.left=current}'=='|{NoInclusion.left=current}'!='|{Different.left=current}'<>'|{Inferrior.left=current}'<'|{Superior.left=current}'>'|{SuperiorOrEqual.left=current}'>='|{InferriorOrEqual.left=current}'<=') right=ConditionalOR)*;
ConditionalOR returns Expression:
Addition (({ConditionalOR.left=current} 'or'|{ConditionalOX.left=current} 'ox'|{ConditionalAND.left=current} 'and'|{ConditionalNOT.left=current} 'not') right=Addition)*;
Addition returns Expression:
Multiplication (({Plus.left=current} '+' | {Minus.left=current} '-') right=Multiplication)*;
Multiplication returns Expression:
PrimaryExpression (({Multi.left=current} '*' | {Div.left=current} '/') right=PrimaryExpression)*;
PrimaryExpression returns Expression:
NumericInt|NumericReal|StringLiteral //|Call
| VariableOperande
| '(' Expression ')' ;
StringLiteral:
stringValue=STRING;
NumericInt:
value=INT;
NumericReal:
value=REAL;
VariableOperande:
variable=[VariableDeclaration];
VariableDeclaration:
'dcl' name = ID type=Type //| ('like' variable=[VariableDeclaration]))
('endloc')?('[,S]')?
Type:
ShortNumericType | NumericType | StringType | BCDType
ShortNumericType:
{ShortNumericType}'#';
NumericType:
{NumericType}'%';
StringType:
{StringType}'$'('='size=INT)?;
BCDType:
{BCDType}('='size=INT)?;
terminal ID : ('a'..'z'|'A'..'Z') ('a'..'z'|'A'..'Z'|'0'..'9')*;
terminal INT returns ecore::EInt: ('0'..'9')+;
terminal REAL returns ecore::EDouble : INT '.' INT;
terminal STRING :
'"' ( '\\' ('b'|'t'|'n'|'f'|'r'|'u'|'"'|"'"|'\\') | !('\\'|'"') )* '"' |
"'" ( '\\' ('b'|'t'|'n'|'f'|'r'|'u'|'"'|"'"|'\\') | !('\\'|"'") )* "'"
terminal SL_COMMENT : (';') !('\n'|'\r')* ('\r'? '\n')?;
terminal WS : (' '|'\t'|'\r'|'\n')+;
test with xtend:
class test{
@Inject extension ParseHelper<CompilationUnit>
@Test def void testBadProgramDeclaration() {
val compilationUnit=
if(a and b)
dcl a%
dcl b%
'''.parse
Assert::assertNotNull(compilationUnit)
val compilalionUnit= compilationUnit.instructions.get(0)
val ifstatement= compilalionUnit as Ifstatement
val expression2= ifstatement.expressions
Assert::assertTrue(expression2 instanceof ConditionalAND)
val conditionalAND=expression2 as ConditionalAND
Assert::assertNotNull(conditionalAND)
Assert::assertNotNull(conditionalAND.left)
Assert::assertTrue(conditionalAND.left instanceof VariableOperande)
val variableOperande = conditionalAND.left as VariableOperande
Assert::assertNotNull(variableOperande.variable)
Assert::assertEquals('a',variableOperande.variable.name)
Assert::assertNotNull(conditionalAND.right)
Assert::assertTrue(conditionalAND.right instanceof VariableOperande)
val rightVariableOperande = conditionalAND.right as VariableOperande
Assert::assertNotNull(rightVariableOperande.variable)
Assert::assertEquals('b',rightVariableOperande.variable.name)
this test is correct but it shouldn't be
because they don't have endif
Maybe somebody has an idea or can point me into the right direction? Thanks in advance!
Jérôme
Previous Topic:Make my model nodes implement an interface?
Next Topic:Register variables in xtext block of code
Current Time: Tue Apr 16 16:56:20 GMT 2024
Powered by FUDForum. Page generated in 1.74410 seconds
