Home » Eclipse Projects » EGit / JGit » modify the EGit source
modify the EGit source [message #901150] Fri, 10 August 2012 02:19 Go to next message
I want to add a simple function to EGit.
so, Is it possible to modify the source and create a jar file(plugin) in My Eclipse? (without Contributing Patches)
Re: modify the EGit source [message #901159 is a reply to message #901150] Fri, 10 August 2012 03:36 Go to previous messageGo to next message
If you modify the existing source, then you need to make it available to
the public, normally by attaching it to a bug.
Dani
Re: modify the EGit source [message #901278 is a reply to message #901159] Fri, 10 August 2012 11:26 Go to previous message
If you want to experiment and build a modified EGit follow the build instructions [1]
which create a p2 repository you can use to install your modified version from.
[1] http://wiki.eclipse.org/EGit/Contributor_Guide#Builds
Previous Topic:Commit causes lengthy reindexing of repository
Next Topic:Remote helper integration
Current Time: Sun Jul 13 16:17:21 EDT 2025
Powered by FUDForum. Page generated in 0.25795 seconds
