Re: Undo in IE [message #900945 is a reply to message #900937] |
Thu, 09 August 2012 07:47 |
Ivan Furnadjiev Messages: 2426 Registered: July 2009 Location: Sofia, Bulgaria |
Hi Michael,
the context menu of the text field is the "native" browser context menu
and RAP does not control its behavior in any way. If you type something
in the field the "Undo" menu item is enabled. If there are differences
between the browsers we can't do anything about it.
Best,
Ivan
On 8/9/2012 10:24 AM, Michael Klein wrote:
> Hi.
> I noticed the undo action in the context menu of text fields has
> different enablement behaviour:
> - in applications that use the Eclipse workbench, the undo action is
> always disabled.
> - in plain RWT applications, the undo action is enabled (if there is
> anything to undo).
> I suppose the action is not an Eclipse action, but a native browser
> action. But this doesn't explain, why the action works in one case but
> not in the other.
> The problem occurs in IE only. In FF the undo action is also enabled
> for applications that use the Eclipse workbench. This can be
> reproduced with the RAP demos (http://eclipse.org/rap/demos/). In "RAP
> Examples" the undo action is enabled in IE, in "RAP Workbench Demo" it
> isn't.
> Can anybody explain the difference or give a hint, how to get the undo
> action working for IE in applications that use the Eclipse workbench.
> Regards,
> Michael
Ivan Furnadjiev
Twitter: @EclipseRAP
FUDForum. Page generated in 0.03084 seconds
