Home » Archived » BIRT » Using JDBC for datasource not showing all of Schema(Using JDBC for datasource not showing all of Schema)
Using JDBC for datasource not showing all of Schema [message #900907] Wed, 08 August 2012 23:15 Go to next message
passer by is currently offline passer byFriend
In sql developer I am seeing all the data tables and functions but when looking through my datasource in birt i am only seeing half of schemas and tables? I have the filter set to show all. How can I view/get access to all my data schemas/tables. Thanks
Re: Using JDBC for datasource not showing all of Schema [message #901068 is a reply to message #900907] Thu, 09 August 2012 15:28 Go to previous message
Jason Weathersby is currently offline Jason WeathersbyFriend
You can set the number of schemas displayed in the preferences. See
attached image.
Jason
Previous Topic:renderTask images not found when rendering pdf
Next Topic:BIRT pdf report print issue in pdf complete
Current Time: Fri Mar 31 16:12:36 GMT 2023
Powered by FUDForum. Page generated in 0.01266 seconds
