Chart Axis script not working [message #900811] |
Wed, 08 August 2012 10:52  |
I am utilizing a script and a parameter to change the X axis on a chart that I am tasked with creating. It works beautifully in BIRT, but when I publish it to our EssentiaRX system, it gives this error message:
"TypeError: Cannot call method "getReportItem" of null (/report/method[@name="beforeFactory"]#5)."
Here is the script:
importPackage( Packages. org.eclipse.birt.chart.model);
importPackage (Packages.org.eclipse.birt.chart.model.attribute );
cht = reportContext.getDesignHandle().findElement("mychart1");
mychart = cht.getReportItem().getProperty( "chart.instance" );
xAxis =mychart.getAxes().get(0);
xSeriesDef = xAxis.getSeriesDefinitions().get(0);
xGrouping = xSeriesDef.getGrouping();
if (params["Period"].value == "Week"){
xGrouping.setGroupingUnit(GroupingUnitType.WEEKS_LITERAL);
else if (params["Period"].value == "Month"){
xGrouping.setGroupingUnit(GroupingUnitType.MONTHS_LITERAL);
else if (params["Period"].value == "Year"){
xGrouping.setGroupingUnit(GroupingUnitType.YEARS_LITERAL);
We are using BIRT 2.3.1 in Eclipse 3.4.1 as near as I can tell. Thanks for any assistance.
Re: Chart Axis script not working [message #900850 is a reply to message #900846] |
Wed, 08 August 2012 13:32   |
Also can you add this to the script?
importPackage( Packages.java.io );
out = new PrintWriter( new FileWriter( "c:/temp/chtevents.txt", true ) );
out.println( "Test " + cht);
out.close();
And post what is in chtevents.txt after running on the server.
Jason
On 8/8/2012 1:29 PM, Jason Weathersby wrote:
> Can you post the report?
> On 8/8/2012 1:24 PM, Michael Harless wrote:
>> Jason,
>> Thanks for the quick reply. Straight off of my screen: BIRT Report
>> Designer, Version: 2.3.1.v20080630-7X7n7FECLqlyX1jw48bOyH4E0ha5, Build
>> I tried the code that you suggested and again, it worked fine in the
>> designer, but when published into our EssentiaRX system, it gives the
>> same error as before.
>> Mike
Re: Chart Axis script not working [message #900896 is a reply to message #900880] |
Wed, 08 August 2012 17:14  |
Sounds like a good idea. Let us know what you find out.
Jason
On 8/8/2012 3:33 PM, Michael Harless wrote:
> Jason,
> It didn't help. I'm still getting the same error. I think that we need
> to send a copy of this to LWSI and see if they can help. Thanks so much.
> Mike
FUDForum. Page generated in 0.05906 seconds
