Home » Eclipse Projects » EPF » Too many Plug-ins(Too many plug-ins on the library)
Too many Plug-ins [message #900606] Tue, 07 August 2012 18:28 Go to next message
Sidronio Lima is currently offline Sidronio LimaFriend
Hi.
I'm new on the EPF and I'm doing the tutorials, but some issues have appeared. In the begining of the tutorial I need to select the publish.openup.base in the referenced plug-ins panel. But it wasn't there. So I downloaded the EPF Practices library, but when I open appears so many others plug-ins. In further steps if I don't have these plug-ins I cannot select the disciplines to categorize a task for example. Will I use them all? That's normal or what I'm doing wrong?
Thanks.
  • Attachment: prtscn.png
    (Size: 126.28KB, Downloaded 274 times)
Re: Too many Plug-ins [message #996733 is a reply to message #900606] Wed, 02 January 2013 20:02 Go to previous message
Bruce MacIsaac is currently offline Bruce MacIsaacFriend
Member
yes, this is normal.
You need to work with the full library of plug-ins.
You can select or deselect plug-ins as part of defining a configuration - this will determine what end users will see.
Previous Topic:External URL links prevent display of website
Next Topic:Server Configuration
Current Time: Sat Dec 05 15:56:30 GMT 2020
Powered by FUDForum. Page generated in 0.01859 seconds
