Home » Modeling » TMF (Xtext) » Custom extensions when using EcoreGeneratorFragment?
Custom extensions when using EcoreGeneratorFragment? [message #900518] Tue, 07 August 2012 11:25 Go to next message
Bastian Mueller is currently offline Bastian MuellerFriend
I'd like to extend the generated metamodel of an Xtext grammar with methods.
I followed the blog post on Christian Dietrich's Blog (the forum doesn't allow me to post non-eclipse.org links, sorry) and implemented a post processor as proposed.
The first comment also notes it is possible to extend a manually maintained model by specifying the srcPath in the EcoreGenerator component.
Is there any way to add custom extensions when inferring/generating the metamodel from the grammar (using EcoreGeneratorFragment) in Xtext?
Re: Custom extensions when using EcoreGeneratorFragment? [message #900865 is a reply to message #900518] Wed, 08 August 2012 18:21 Go to previous message
Christian Dietrich is currently offline Christian DietrichFriend
there is no out of the box functionality for that you would have to patch parts from
org.eclipse.emf.mwe2.ecore.EcoreGenerator into org.eclipse.xtext.generator.ecore.EcoreGeneratorFragment
~Christian
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Previous Topic:test error with xtend
Next Topic:How to resolve ambiguity with label syntax
Current Time: Mon Mar 01 04:40:09 GMT 2021
Powered by FUDForum. Page generated in 0.01484 seconds
