Home » Language IDEs » C / C++ IDE (CDT) » Windows SDK with CDT(using MS free compiler tools with CDT)
Windows SDK with CDT [message #900502] |
Tue, 07 August 2012 10:18 |
Earlier, I was using Qt Creator IDE with Windows SDK tools and it works perfect,
no extra settings, QtCreator "sees" that Windows SDK is installed and uses
compiler/debugging tools and libs/headers from this SDK for C++ projects
Unfortunatelly CDT doesn't see that compiler kit (I mean Windows SDK) already installed and doesn't suggest me simply to use this..
and I couldn't find any manuals how to configure this
Could you help me with this?
is here anyone who uses CDT under Windows platform with Microsoft C++ compiler/libs?
[Updated on: Wed, 08 August 2012 07:40] Report message to a moderator
Re: Windows SDK with CDT [message #901396 is a reply to message #901326] |
Sat, 11 August 2012 18:03 |
No,
thank you for the URLs,
I've quickly reviewed these, downloaded latest CDT (seems the support for microsoft tools was inluded in latest CDT?)
and tried to build with Visual C++ toolchain
and with MinGW
in both cases, there is a message:
sh -c "autoreconf -i"
Cannot run program "sh": Launching failed
Error: Program "sh" not found in PATH
can't find out where is a setting for this command?
1. for windows sdk: seems that CDT can't work with Windows SDK debugger?
2. for mingw: debugging raises an error "Error in services launch sequence
Unhandled exception when executing Sequence org.eclipse.cdt.dsf.gdb.launching.ServicesLaunchSequence@1c0c995, step #4
java.lang.NullPointerException"
Too many problems in this IDE for simplest operation - build "Hello World" project
in Qt Creator, all this works by one click
[Updated on: Sat, 11 August 2012 19:50] Report message to a moderator
Re: Windows SDK with CDT [message #901432 is a reply to message #901396] |
Sun, 12 August 2012 08:47 |
Joost Kraaijeveld Messages: 273 Registered: July 2009 |
On 11/08/12 20:03, Ernst Mising name wrote:
> No,
> and tried to select Visual C++ toolchain in project properties
> but it doesn't work for me in any case.
> 1. if checkbox "show compatible toolchains only" is flaged , then visual
> c++ is not available.
This means that you have not installed Visual C++ (correctly).
> 2. without flag (from point1), I've set Visual C++ toolchain but see the
> messages from compiler:
> Program "gcc" not found in PATH
> Program "g++" not found in PATH
> CDT bug?
No, see above.
Groeten,
Joost Kraaijeveld
Askesis B.V.
Molukkenstraat 14
6524NB Nijmegen
tel: 024-3888063 / 06-51855277
fax: 024-3608416
web: www.askesis.nl
Joost
Re: Windows SDK with CDT [message #901533 is a reply to message #901503] |
Mon, 13 August 2012 09:28 |
Thank you for the replies!
First of all - I've compiled the project using micrsoft toolchain, thank you!
as I said above , I didn't install Visual C++, I believe that Windows SDK is enough, it includes all required libraries , compiler/linker and debugger.
about "sh", thanks for the link, I'm going to read this
now, the primary issue for me is the debugging , I don't see where and how I can set up the debugger from Windows SDK, I see all debugger settings in CDT UI regards to GDB only....
Re: Windows SDK with CDT [message #901686 is a reply to message #901533] |
Tue, 14 August 2012 07:33 |
Axel Mueller Messages: 1973 Registered: July 2009 |
Ernst Mising name wrote on Mon, 13 August 2012 11:28Thank you for the replies!
There is no debug support for Visual C++. You can only use the compiler. If you want to debug you have to compile your project with MinGW and then use gdb (gdb does not understand the debug symbols from Visual C++).
Before you ask
- search this forum
- see the FAQ http://wiki.eclipse.org/CDT/User/FAQ
- google
Current Time: Tue Nov 05 07:06:37 GMT 2024
Powered by FUDForum. Page generated in 0.03551 seconds
