Home » Eclipse Projects » Remote Application Platform (RAP) » Could not evaluate javascript response(Could not evaluate javascript response)
Could not evaluate javascript response [message #900367] Mon, 06 August 2012 16:42 Go to next message
Nuruddin Hakimjee is currently offline Nuruddin HakimjeeFriend
Our RAP application is built on RAP 1.4.2
We have a few users who are experiencing the following error:
Could not evaluate javascript response:
Error: TypeError: a is undefined
Script: var wm = org.eclipse.swt.WidgetManager.getInstance();var w = wm.findWidgetById( "w1619" );w.dispose();var w = wm.findWidgetById( "w1620" );w.dispose();var w = wm.findWidgetById( "w1621" );w.dispose();var req = org.eclipse.swt.Request.getInstance();req.setRequestCounter( "74" );var w = wm.findWidgetById( "w116" );w.setEnabled( true );var w = wm.findWidgetById( "w117" );w.setEnabled( true );var w = wm.findWidgetById( "w152" );w.setEnabled( true );var w =
fileName: https://<ip address>/app/isf?custom_service_handler=org.eclipse.rwt.internal.resources.JSLibraryServiceHandler&hash=H-754676235
lineNumber: 170
Debug: off
Request: org.eclipse.swt.events.widgetSelected=w298&w1.cursorLocation.x=227&w1.cursorLocation.y=299&uiRoot=w1&requestCounter
This is an intermittent error which we cannot reproduce and I do not know how to debug this error.
Any pointers/help will be much appreciated.
Nuruddin
Re: Could not evaluate javascript response [message #900435 is a reply to message #900367] Tue, 07 August 2012 05:54 Go to previous messageGo to next message
Ivan Furnadjiev is currently offline Ivan FurnadjievFriend
without a way to reproduce the issue we couldn't help much. You could
turn DEBUG client variant ON in order to get a little bit more
informative error message.
Best,
Ivan
On 8/6/2012 7:42 PM, Nuruddin Hakimjee wrote:
> Hello,
> lineNumber: 170
> Debug: off
> Request:
> Nuruddin
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: Could not evaluate javascript response [message #901646 is a reply to message #900435] Mon, 13 August 2012 19:46 Go to previous messageGo to next message
Hello Ivan,
Thank you for the response. Is line number 170 referring to JSLibraryServiceHandler? And if so where would I find that file? Whenever the error occurs, it is always on line 170.
Nuruddin
Re: Could not evaluate javascript response [message #901672 is a reply to message #901646] Tue, 14 August 2012 05:20 Go to previous messageGo to next message
JSLibraryServiceHandler was (removed in RAP 1.5) a service handler that
delivered the framework javascript library on the application start. The
error at line 170 is not in the JSLibraryServiceHandler file, but in the
javascript returned by it.
Best,
Ivan
On 8/13/2012 10:46 PM, Nuruddin Hakimjee wrote:
> Hello Ivan,
> Nuruddin
Ivan Furnadjiev
Re: Could not evaluate javascript response [message #903180 is a reply to message #901672] Wed, 22 August 2012 12:35 Go to previous messageGo to next message
Hello Ivan,
Sorry for the delayed response. I was able to figure out that the error is coming from the table.js but I have been unable to narrow it down any further.
How would I turn on debugging? I would need to do turn it on the production server as I am unable to duplicate this issue locally.
Nuruddin
Re: Could not evaluate javascript response [message #903679 is a reply to message #903180] Fri, 24 August 2012 21:03 Go to previous message
Ralf Sternberg is currently offline Ralf SternbergFriend
the only way to turn on debug mode is to set the system property
"org.eclipse.rwt.clientLibraryVariant" to "DEBUG".
Obviously, the crash happens in response to a selection event. It's
unlikely that it happens at random, there will be certain preconditions.
You could try to find the pattern behind the crashes. What user action
provokes the error? Clicking on a certain button, a table item? What
happens in the selection listeners in this case? Is a widget being
disposed that is part of the selection... something like this. If you
can find a suspicious pattern that might help to prepare a workaround.
It's easier to track down those kind of errors with the new protocol in
RAP 1.5.
HTH, Ralf
Ralf Sternberg
Previous Topic:Workspace in RAP
Next Topic:Input masking on Text
Current Time: Sun Nov 28 03:36:02 GMT 2021
Powered by FUDForum. Page generated in 0.01820 seconds
