Home » Modeling » TMF (Xtext) » Rename/Move Resource refactoring for importURI-style includes
Rename/Move Resource refactoring for importURI-style includes [message #900361] Mon, 06 August 2012 15:43 Go to next message
Dénes Harmath is currently offline Dénes HarmathFriend
Hi all,
I have a DSL using the importURI mechanism. If a file is renamed/moved in the workspace, I want to update all import statements referencing it to refer to the new path. Is there a standard solution for this in Xtext or do I have to manually iterate through all the resources in the workspace, find all the import statements in their EObjects and create the LTK changes for them? If the latter is the case, what is the most effective way to do this, and should I file an enhancement request for a generic implementation?
Thank you in advance,
thSoft
Re: Rename/Move Resource refactoring for importURI-style includes [message #900787 is a reply to message #900361] Wed, 08 August 2012 13:27 Go to previous message
In the meantime, I implemented this functionality. Smile Here it is: http://code.google.com/a/eclipselabs.org/p/elysium/source/browse/#git%2Forg.elysium.ui%2Fsrc%2Forg%2Felysium%2Fui%2Frefactoring
Previous Topic:problem with string rule and double quote rule
Next Topic:Triggering generator using context menu in xtext
Current Time: Sun Jan 24 23:12:08 GMT 2021
Powered by FUDForum. Page generated in 0.02313 seconds
