Home » Modeling » GMF (Graphical Modeling Framework) » Problem in generating Code
Problem in generating Code [message #900333] Mon, 06 August 2012 14:22 Go to next message
Sarath Rachakonda is currently offline Sarath RachakondaFriend
Hi Everyone,
Iam trying to generate code for simple GMF model mentioned in ttp://gmfsamples.tuxfamily.org/wiki/doku.php?id=gmf_tutorial1
Iam using eclipse juno (latest stable release - Eclipse Juno (4.2) Package)
When i try to generate diagram code iam getting following error
Problems while generating code
Exception (Boolean expected (was: org.eclipse.ocl.ecore.internal.OCLStandardLibraryImpl$1)!:in CodeStyle, line 18) while generating code
Exception (Boolean expected (was: org.eclipse.ocl.ecore.internal.OCLStandardLibraryImpl$1)!:in CodeStyle, line 77) while generating code
Exception (Boolean expected (was: org.eclipse.ocl.ecore.internal.OCLStandardLibraryImpl$1)!:in CodeStyle, line 83) while generating code
Exception (Boolean expected (was: org.eclipse.ocl.ecore.internal.OCLStandardLibraryImpl$1)!:in CodeStyle, line 19) while generating code
Exception (Boolean expected (was: org.eclipse.ocl.ecore.internal.OCLStandardLibraryImpl$1)!:in CodeStyle, line 49) while generating code
Exception (Boolean expected (was: org.eclipse.ocl.ecore.internal.OCLStandardLibraryImpl$1)!:in xpt::plugin::manifest, line 78) while generating code
Your help is appreciated
Sarath
  • Attachment: file.genmodel
    (Size: 1.51KB, Downloaded 353 times)
  • Attachment: file.gmfgraph
    (Size: 2.44KB, Downloaded 359 times)
  • Attachment: file.gmfmap
    (Size: 2.41KB, Downloaded 310 times)
  • Attachment: file.gmftool
    (Size: 1.52KB, Downloaded 578 times)
  • Attachment: file.gmfgen
    (Size: 15.94KB, Downloaded 348 times)
[Updated on: Tue, 07 August 2012 12:06]
Report message to a moderator
Re: Problem in generating Code [message #900623 is a reply to message #900333] Tue, 07 August 2012 19:59 Go to previous messageGo to next message
Aurélien Pupier is currently offline Aurélien PupierFriend
Can you check that you are using OCL version shipped with Juno please?
Can you provide your .ecore file?
It seems that you are not using explicitly OCL. Can you confirm it? if you are using it, can you precise where please?
Aurélien Pupier - Red Hat
Senior Software Engineer in Fuse Tooling team
Re: Problem in generating Code [message #900760 is a reply to message #900623] Wed, 08 August 2012 12:19 Go to previous messageGo to next message
Hi Aurelien ,
Iam not using OCL explicitly. Instead i have Updated OCL end user SDK through update site. Even after uninstalling OCL it is showing same error.
Please find the ecore file and list of installed updates in the attachments
Sarath
Re: Problem in generating Code [message #900765 is a reply to message #900760] Wed, 08 August 2012 12:27 Go to previous messageGo to next message
Ralph Gerbig is currently offline Ralph GerbigFriend
do you have written any OCL constraint somewhere in the mapping model? If yes can you please post it? Your ecore meta-model does not seem to contain OCL.
Ralph
Re: Problem in generating Code [message #900786 is a reply to message #900765] Wed, 08 August 2012 13:27 Go to previous messageGo to next message
Hi Ralph,
I haven't written any OCL constraint
Sarath
Re: Problem in generating Code [message #900814 is a reply to message #900786] Wed, 08 August 2012 15:15 Go to previous messageGo to next message
Andres Alvarez Mattos is currently offline Andres Alvarez MattosFriend
I´m having the same problem with the last June version. I downloaded the Modeling Tools version.
Re: Problem in generating Code [message #900934 is a reply to message #900814] Thu, 09 August 2012 07:13 Go to previous messageGo to next message
Joel Greenyer is currently offline Joel GreenyerFriend
Me too. (Juno Modeling Tools, no explicit OCL use in model or graphical mapping.)
Any solutions yet?
Joel
Re: Problem in generating Code [message #900987 is a reply to message #900934] Thu, 09 August 2012 10:15 Go to previous messageGo to next message
Found Solution. Problem is because of Java version. Once we generate .genModel file we need to set 'Compliance level' in properties of genmodel to 6.0.
Problem is because of 7.0
Re: Problem in generating Code [message #901020 is a reply to message #900987] Thu, 09 August 2012 12:39 Go to previous messageGo to next message
Great, works fine now. Thanks !!
Re: Problem in generating Code [message #1011833 is a reply to message #901020] Wed, 20 February 2013 10:34 Go to previous messageGo to next message
Stephan Schmidt is currently offline Stephan SchmidtFriend
A coworker and myself experienced this problem independently of each other. Problems like these are very frustrating, as it is nigh impossible to find proper documentation for these issues. At the current stage, it seems the state of the GMF documentation is quite poor. People interested in GMF still learn through the tutorials (which do a good job at introducing to GMF), but then you are on your own.
In my opinion, it would be helpful to have a central location for all documentation - API, Tutorials, Howtos, Explanation of GMFModel file properties (gmfmap, gmfgen, ...). At the moment, the wiki is in a very unorganized state. I don't know if this is due to the migration from an old wiki or what is the issue here - many dead links, empty pages and so on.
Hopefully I don't come across as overly negative here - I am truly thankful for GMF and its contributors, and it is a great tool - if you know what you are doing! But growing the userbase will be difficult if frustrations like this occur, where solutions are found only in newsgroups instead of comprehensive documentation/FAQs.
Stephan
Re: Problem in generating Code [message #1666643 is a reply to message #1011833] Wed, 11 March 2015 19:55 Go to previous messageGo to next message
Marco Descher is currently offline Marco DescherFriend
This is still applicable to current Luna. Setting genmodel to compliance 6.0 is required. Maybe setting this compliance level should be part in the Dashboard configuration?
Re: Problem in generating Code [message #1733904 is a reply to message #900333] Thu, 02 June 2016 06:47 Go to previous messageGo to next message
This is still applicable to current Neon. Setting genmodel to compliance 6.0 is required. Maybe setting this compliance level should be part in the Dashboard configuration?
Re: Problem in generating Code [message #1753131 is a reply to message #900333] Thu, 02 February 2017 07:04 Go to previous message
Marco Bonilla is currently offline Marco BonillaFriend
Hi all,
I'm a newie on Eclipse specifically on GMF
I have generated the model, mapping, graphics and so, but now I get the error posted here. Where can I find help about how to fix it? I tried changing the compliance as showed on web but didn't work. Anybody could post the steps that I could follow please?
Previous Topic:Have questions about GMF.
Next Topic:Update programmatically figure with EditPart
Current Time: Wed Mar 03 06:53:28 GMT 2021
Powered by FUDForum. Page generated in 0.02189 seconds
