Re: Tab placement always remove most used window [message #990654 is a reply to message #990630] |
Thu, 13 December 2012 15:28 |
Sheldon Glickler Messages: 5 Registered: December 2012 |
I looked at that one now. That one seems to be only about the drop-down list from the chevron. I am more interested in the open windows. Also, the previous version's dropdown list was actually two lists. The first was the windows not showing in tabs and the next was the list showing in tabs and that one was bolded. Both were in alphabetical order. I liked that list also better than the current one.
[Updated on: Thu, 13 December 2012 15:47] Report message to a moderator
Re: Tab placement always remove most used window [message #991329 is a reply to message #991325] |
Tue, 18 December 2012 14:36 |
Wow. Thanks, Was that all there was to it? I turned it to Classic and it behaves properly. Is Windows Classic the same thing?
Also, the old way had two lists when you clicked the Chevron at the upper right (if there were more tabs than were visible). The first list was alphabetical and not bolded and was the list of tabs not showing. The second list was also alphabetical, bolded, and showed the list of tabs that were visible on the screen. The current version only has one, alphabetized, not bolded, list. Can I get the previous behavior?
[Updated on: Tue, 18 December 2012 14:37] Report message to a moderator
FUDForum. Page generated in 0.02337 seconds
