Home » Archived » BIRT » BIRT pdf report print issue in pdf complete(BIRT pdf print issue in pdf complete)
BIRT pdf report print issue in pdf complete [message #899998] Fri, 03 August 2012 11:41 Go to next message
suganya c is currently offline suganya cFriend
I have a pdf file which got exported from BIRT report. I tried opening that pdf file in adobe acrobat and tried printing it. It got printed properly.
But when i try to open the same pdf file using PDF complete and print it. Nothing gets printed. But the pdf file is getting opened in PDF complete properly.
Is birt pdf report not compatible with printing using pdf complete or so.?
Please any of you tell me solution for it. Its really Urgent.
I have attached a sample pdf report exported using birt. It will not print anything if you open and print it via pdf complete.
Thanks in advance.
  • Attachment: index.pdf
    (Size: 1.01KB, Downloaded 218 times)
Re: BIRT pdf report print issue in pdf complete [message #900078 is a reply to message #899998] Fri, 03 August 2012 19:58 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Do you get any error?
Jason
> Thanks in advance.
Re: BIRT pdf report print issue in pdf complete [message #900121 is a reply to message #900078] Sat, 04 August 2012 08:56 Go to previous messageGo to next message
No.Not getting any error. But data alone from pdf exported file from BIRT is not getting printed when it is opened and printed via pdf complete.
If pdf exported file from BIRT contains table with data in it, then table alone is getting printed, but not the data is getting printed. This is happening when that pdf report is opened and printed via PDF complete.
Re: BIRT pdf report print issue in pdf complete [message #900391 is a reply to message #900121] Mon, 06 August 2012 20:25 Go to previous messageGo to next message
Are you doing this from the BIRT designer? Or are you exporting the pdf
and then opening it in pdf complete?
Jason
> complete.
Re: BIRT pdf report print issue in pdf complete [message #900430 is a reply to message #900391] Tue, 07 August 2012 05:31 Go to previous messageGo to next message
I am exporting the PDF and opening it in PDF complete.
Re: BIRT pdf report print issue in pdf complete [message #900520 is a reply to message #900430] Tue, 07 August 2012 11:33 Go to previous messageGo to next message
It is not getting printed even BIRTdesigner is used.
Re: BIRT pdf report print issue in pdf complete [message #900570 is a reply to message #900520] Tue, 07 August 2012 15:04 Go to previous messageGo to next message
Suganya,
Do you only get this issue with BIRT created PDFs?
Jason
Re: BIRT pdf report print issue in pdf complete [message #900783 is a reply to message #900570] Wed, 08 August 2012 13:13 Go to previous messageGo to next message
Yes.
Re: BIRT pdf report print issue in pdf complete [message #900832 is a reply to message #900783] Wed, 08 August 2012 16:31 Go to previous messageGo to next message
You may need to open a bugzilla entry for this. I assume you do not get
anything in the event log?
Jason
On 8/8/2012 9:13 AM, suganya c wrote:
> Yes.
Re: BIRT pdf report print issue in pdf complete [message #900926 is a reply to message #900832] Thu, 09 August 2012 06:24 Go to previous messageGo to next message
Yes. There is no event log information. I created the bugzilla entry [Bug 386903].
Re: BIRT pdf report print issue in pdf complete [message #901069 is a reply to message #900926] Thu, 09 August 2012 15:29 Go to previous message
Thanks for posting the bug number.
Jason
> [Bug 386903].
Previous Topic:Using JDBC for datasource not showing all of Schema
Next Topic:Dynamically set table name in onPrepare method
Current Time: Mon Mar 27 04:21:57 GMT 2023
Powered by FUDForum. Page generated in 0.02625 seconds
