Home » Eclipse Projects » Jubula » press "Start AUT" and get '5009: AUT start failed No valid Java binary found.'(error message when try to start test object)
press "Start AUT" and get '5009: AUT start failed No valid Java binary found.' [message #899804] Thu, 02 August 2012 12:04 Go to next message
Erik Gilbert is currently offline Erik GilbertFriend
Member
trying to run the example in the article:
"UI Testing with Eclipse Jubula" at jmhofer's insignificant insights site:
jmhofer.johoop.de/?p=97
able to get through the example until
start the test object via the "Start AUT" toolbar button.
was able to start successfully the 'AUT Agent' service and connect to it.
But the next step of pressing the "Start AUT" button brings up the error message:
An error occurred.
Reason: 5009: AUT start failed
No valid Java binary found. Check given JRE binary.
Anyone know the reason for this error or how to fix it?
I have both the Java 1.7 JRE installed and Java EE 6 SDK installed. Haven't had any other problems with the Java binary. The binary is in the PATH environment variable.
Re: press "Start AUT" and get '5009: AUT start failed No valid Java binary found.' [message #900343 is a reply to message #899804] Mon, 06 August 2012 14:52 Go to previous messageGo to next message
Alexandra Schladebeck is currently offline Alexandra SchladebeckFriend
Judging from your later posts, can I assume that you got the AUT started?
Alex
Re: press "Start AUT" and get '5009: AUT start failed No valid Java binary found.' [message #1172315 is a reply to message #900343] Tue, 05 November 2013 21:17 Go to previous messageGo to next message
Bernard Rossi is currently offline Bernard RossiFriend
What was the solution?
Bernard
Re: press "Start AUT" and get '5009: AUT start failed No valid Java binary found.' [message #1765313 is a reply to message #1172315] Thu, 08 June 2017 10:29 Go to previous message
muthuk ponnusamy is currently offline muthuk ponnusamyFriend
Please check the Path of the AUT : By Verifing
Test --> Properties --> AUT's --> Open Project (XXX) --> Under AUT configurations Edit ---> check Executable File Name [ Here Verify that the Application is availabel in the Path].
Muthu
Previous Topic:Read file in Jubula
Next Topic:working with multiple AUTs using jubula java api
Current Time: Sun Aug 09 11:58:42 GMT 2020
Powered by FUDForum. Page generated in 0.02100 seconds
