Home » Eclipse Projects » BIRT » BIRT 3.7.2 Report Viewer on designer doesn't load the reports
BIRT 3.7.2 Report Viewer on designer doesn't load the reports [message #899496] Wed, 01 August 2012 07:56 Go to next message
Rama Krishna is currently offline Rama KrishnaFriend
I'm using BIRT 3.7.2 and have been facing an error with Report Viewer on designer. I get the below error when the report is viewed by clicking the button for "View report in Web Viewer" on the designer.
A Runtime Error has occurred.Do you wish to Debug?
Line: 84
Error: Object expected
I could fix the issue in runtime birt webapp deployed in tomcat by setting the parameter "BIRT_VIEWER_PRINT_SERVERSIDE" OFF in web.xml as per the solution in the below topic.
http://www.eclipse.org/forums/index.php/m/364967/
Can someone suggest how to fix this issue on the designer? Without Report viewer on designer, it is very tedious to develop and test the changes for reports by deploying tomcat everytime.
Thank you very much.
Re: BIRT 3.7.2 Report Viewer on designer doesn't load the reports [message #899640 is a reply to message #899496] Wed, 01 August 2012 16:01 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Rama,
Select window->preferences->Report Design->Preview. Try checking the
Always use external browsers checkbox. You can click on the Web Browser
link to set which external browser is used.
Jason
> Line: 84
Re: BIRT 3.7.2 Report Viewer on designer doesn't load the reports [message #899698 is a reply to message #899640] Wed, 01 August 2012 22:35 Go to previous messageGo to next message
Hi Jason, I'm facing the same issue even after selecting the external browser.
Report Viewer was working fine initially on both designer and on browser when deployed in tomcat, not sure what caused this issue later. But I could have a workaround in runtime version by setting BIRT_VIEWER_PRINT_SERVERSIDE parameter OFF in web.xml. Can we have a similar fix in designer version also?
Re: BIRT 3.7.2 Report Viewer on designer doesn't load the reports [message #899838 is a reply to message #899698] Thu, 02 August 2012 14:19 Go to previous message
What OS are you running BIRT on? Have you tried a running eclipse with
the -clean option?
Jason
> browser.
Previous Topic:BIRT 4.2.0
Next Topic:Dynamic dataset creation on the mouseclick event of a chart
Current Time: Sun Nov 28 05:50:11 GMT 2021
Powered by FUDForum. Page generated in 0.02157 seconds
