NullPointerException on charts after upgrade from 2.5.2 to 3.7.2 [message #899435] |
Tue, 31 July 2012 19:12 |
Plamen Todorov Messages: 5 Registered: July 2012 |
Hello, we recently upgraded to 3.7.2 and started experiencing the exception listed below on our line charts. The problem appears only in the Web viewer while it works fine in the designer.
Our environment is:
Java 1.5
BIRT 3.7.2
Weblogic 10.3.2.0
Oracle 11g + ojdbc5
The report itself is kind of complex with many dependencies, and I was unable to create a simple report that reproduces the problem. I am also unable to identify which part is incompatible with 3.7.2. I also tried upgrading to 4.2.0 - same problem.
Has anyone faced this or similar issue? I'm not posting it as a bug since I can't provide enough information for possibly debugging it. Attaching an archive with the report files (but it can't be run without a DB).
Thank you in advance
org.eclipse.birt.report.engine.internal.document.v4.ContainerExecutor hasNextChild
WARNING: null
at org.eclipse.birt.report.engine.internal.document.v4.ExtendedItemExecutor.prepareChildExecutor(ExtendedItemExecutor.java:58)
at org.eclipse.birt.report.engine.internal.document.v4.ContainerExecutor.hasNextChild(ContainerExecutor.java:110)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.hasNextChild(WrappedReportItemExecutor.java:86)
at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.execute(HTMLAbstractLM.java:463)
at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.execute(HTMLAbstractLM.java:476)
at org.eclipse.birt.report.engine.layout.html.HTMLListingBandLM.intializeHeaderContent(HTMLListingBandLM.java:98)
at org.eclipse.birt.report.engine.layout.html.HTMLListingBandLM.initialize(HTMLListingBandLM.java:50)
at org.eclipse.birt.report.engine.layout.html.HTMLTableBandLM.initialize(HTMLTableBandLM.java:44)
at org.eclipse.birt.report.engine.layout.html.HTMLLayoutManagerFactory.createLayoutManager(HTMLLayoutManagerFactory.java:40)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.createLayoutManager(HTMLReportLayoutEngine.java:138)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:68)
at org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.layoutChildren(HTMLStackingLM.java:26)
at org.eclipse.birt.report.engine.layout.html.HTMLGroupLM.layoutChildren(HTMLGroupLM.java:117)
at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.layout(HTMLAbstractLM.java:140)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:70)
at org.eclipse.birt.report.engine.layout.html.HTMLTableLM.layoutChildren(HTMLTableLM.java:132)
at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackingLM.resumeLayout(HTMLInlineStackingLM.java:111)
at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackingLM.layoutNodes(HTMLInlineStackingLM.java:160)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
at org.eclipse.birt.report.engine.api.impl.RenderTask$PageRangeRender.render(RenderTask.java:661)
at org.eclipse.birt.report.engine.api.impl.RenderTask.render(RenderTask.java:294)
at org.eclipse.birt.report.service.ReportEngineService.renderReport(ReportEngineService.java:1547)
at org.eclipse.birt.report.service.BirtViewerReportService.getPage(BirtViewerReportService.java:204)
at org.eclipse.birt.report.service.actionhandler.AbstractGetPageActionHandler.doExecution(AbstractGetPageActionHandler.java:238)
at org.eclipse.birt.report.service.actionhandler.AbstractGetPageActionHandler.__execute(AbstractGetPageActionHandler.java:105)
at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:90)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseDocumentProcessor.__executeAction(AbstractBaseDocumentProcessor.java:47)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.executeAction(AbstractBaseComponentProcessor.java:143)
at org.eclipse.birt.report.soapengine.processor.BirtDocumentProcessor.handleGetPage(BirtDocumentProcessor.java:87)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.process(AbstractBaseComponentProcessor.java:112)
at org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingImpl.getUpdatedObjects(BirtSoapBindingImpl.java:66)
at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397)
at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186)
at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323)
at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454)
at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.doPost(BirtSoapMessageDispatcherServlet.java:265)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.service(BirtSoapMessageDispatcherServlet.java:122)
at weblogic.servlet.internal.StubSecurityHelper$ServletServiceAction.run(StubSecurityHelper.java:227)
at weblogic.servlet.internal.StubSecurityHelper.invokeServlet(StubSecurityHelper.java:125)
at weblogic.servlet.internal.ServletStubImpl.execute(ServletStubImpl.java:292)
at weblogic.servlet.internal.TailFilter.doFilter(TailFilter.java:26)
at weblogic.servlet.internal.FilterChainImpl.doFilter(FilterChainImpl.java:56)
at org.eclipse.birt.report.filter.ViewerFilter.doFilter(ViewerFilter.java:68)
at weblogic.servlet.internal.WebAppServletContext$ServletInvocationAction.run(WebAppServletContext.java:3592)
at weblogic.security.acl.internal.AuthenticatedSubject.doAs(AuthenticatedSubject.java:321)
at weblogic.security.service.SecurityManager.runAs(SecurityManager.java:121)
at weblogic.servlet.internal.WebAppServletContext.securedExecute(WebAppServletContext.java:2202)
at weblogic.servlet.internal.WebAppServletContext.execute(WebAppServletContext.java:2108)
at weblogic.servlet.internal.ServletRequestImpl.run(ServletRequestImpl.java:1432)
at weblogic.work.ExecuteThread.execute(ExecuteThread.java:201)
at weblogic.work.ExecuteThread.run(ExecuteThread.java:173)
Attachment: npe.zip
(Size: 111.37KB, Downloaded 234 times)
[Updated on: Tue, 31 July 2012 19:14] Report message to a moderator
Re: NullPointerException on charts after upgrade from 2.5.2 tp 3.7.2 [message #899611 is a reply to message #899435] |
Wed, 01 August 2012 14:54 |
If you remove the charts does the issue occur?
Jason
> Our environment is:
> Java 1.5
> BIRT 3.7.2
> Weblogic 10.3.2.0
> Oracle 11g + ojdbc5
> WARNING: null
> at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
Re: NullPointerException on charts after upgrade from 2.5.2 tp 3.7.2 [message #899843 is a reply to message #899826] |
Thu, 02 August 2012 14:37 |
Plamen
If you remove the charts and then rebuild one of the charts using the
gui does it work?
Jason
On 8/2/2012 9:35 AM, Plamen Todorov wrote:
> Hi Jason, thanks for the reply.
> The error is definitely in rendering the charts, the report in question has 4 charts in a table group and instead of the charts I'm getting the following messages in the output (screenshot attached):
> Chart (id = 1242):
> + null (Element ID:1242)
> Chart (id = 1630):
> + null (Element ID:1630)
> Chart (id = 1631):
> + null (Element ID:1631)
> Chart (id = 1632):
> + null (Element ID:1632)
> Chart (id = 1633):
> + null (Element ID:1633)
> Removing the charts removes the issue too.
> Thanks
Re: NullPointerException on charts after upgrade from 2.5.2 tp 3.7.2 [message #899916 is a reply to message #899898] |
Thu, 02 August 2012 20:15 |
As a test can you set the persistent variable on the onCreate event?
Jason
On 8/2/2012 2:08 PM, Plamen Todorov wrote:
> OK, while recreating the chart I compared it to some other reports which
> were working ok and managed to identify (more like guess) the code which
> is not working in the 3.7.2 report viewer. The data plotted on the chart
> series is determined by the following code:
> var birthWeighCode =
> reportContext.getPersistentGlobalVariable("birthWeighCode");
> row[chartVarMap[params["chartVariable"].value][birthWeighCode]]
> For some reason the first row is returning null on runtime though it
> works ok in designer. The birthWeighCode global variable is initialized
> in the onRender event of the enclosing data grid row and is also used
> elsewhere. Hardcoding the birthWeighCode makes the report run ok.
> Obviously something changed in the 3.7.2 (or some intermeadiate
> releases) which makes the reportContext behave differently at runtime,
> at least in graphs.
Re: NullPointerException on charts after upgrade from 2.5.2 tp 3.7.2 [message #899927 is a reply to message #899921] |
Thu, 02 August 2012 21:55 |
In the designer are you previewing in the WebViewer? BTW, I do not
think setPersistent works in onRender because that commands writes into
the rptdocument and was designed to be used at run time so at render
time (maybe different time or machine) the render engine could get a
variable stored at run time. You may want to look at using
setGlobalVariable at render time which makes a variable global to the phase.
You could also throw in a script like:
importPackage( Packages.java.io );
out = new PrintWriter( new FileWriter( "c:/test/events.txt", true ) );
out.println( "in my render event");
out.close();
Just to check if the event is being called. The onRender should be
getting called.
Jason
On 8/2/2012 5:00 PM, Plamen Todorov wrote:
> OK, onCreate is working onRender doesn't seem to work.
> It seems the event is not being called at all since the same variable is
> being overwritten multiple times in different charts, and still causing
> NPE in each one. I'm puzzled why this happens only at runtime.
FUDForum. Page generated in 0.02866 seconds
