Home » Newcomers » Newcomers » Get Eclipse in Windows startup-menu(Where is the Eclipse "exe" file on my Windows computer?)
Get Eclipse in Windows startup-menu [message #899202] Tue, 31 July 2012 04:09 Go to next message
Kristinn Andersen is currently offline Kristinn AndersenFriend
I have successfully just installed Eclipse to start Java development on my Windows7 PC. The Eclipse programming environment started right after the installation and I even wrote and ran that "Hello world" program.
Then I closed Eclipse, but when I wanted to start again I don't find, or a shortcut to it, in my Windows directories like any other Windows application. Isn't there somewhere an "Eclipse.exe" file? Help!!
Best regards - Kristinn
[Updated on: Tue, 31 July 2012 11:21]
Report message to a moderator
Re: Get Eclipse in Windows startup-menu [message #899331 is a reply to message #899202] Tue, 31 July 2012 13:34 Go to previous messageGo to next message
Russell Bateman is currently offline Russell BatemanFriend
> application. Help!!
This is because Eclipse isn't in fact installed in the Windows sense.
All you did was unzip it to wherever you put it. If you want it in the
start-up menu, you'll have to create and insert a shortcut yourself.
Re: Get Eclipse in Windows startup-menu [message #899354 is a reply to message #899202] Tue, 31 July 2012 14:24 Go to previous message
David Wegener is currently offline David WegenerFriend
eclipse.exe will be in the folder you unzipped Eclipse into.
Previous Topic:not able to see source file in the the PHP explorer window
Next Topic:I need help, I have no idea what's wrong
Current Time: Mon Jun 21 23:46:41 GMT 2021
Powered by FUDForum. Page generated in 0.03238 seconds
