[CDO] Productive Use and Schema Evolution [message #899173] |
Mon, 30 July 2012 20:42 |
Tex Iano Messages: 99 Registered: February 2012 |
Member |
I want to extend my application with collaboration capabilities. For that purpose, I am thinking about migrating from XMI files to CDO/Teneo.
Is CDO already applicable for productive use or is it still a development version?
And what I think what is very important: How do you handle the evolution of the database schema? For example I have several models stored and EMF gets updated to a newer version. Is the schema changed too?
Tex
[Updated on: Mon, 30 July 2012 20:45] Report message to a moderator
Re: [Teneo] Productive Use and Schema Evolution [message #899245 is a reply to message #899180] |
Tue, 31 July 2012 08:25 |
Hi Tex,
Yes indeed Teneo is quite stable, a new version of EMF normally does not change the database schema. If I find a really
breaking issue in Teneo which results in a difference in db schema generation (to solve this issue) then I provide an
option for backward compatibility support.
As Tom describes, if you have extensive changes in your model then the Hibernate is not capable of updating the db
schema correctly. New tables and columns are normally handled automatically by hibernate, deleting columns/tables is not
possible (but most of the time less relevant when updating models).
gr. Martin
On 07/30/2012 11:22 PM, Tom Schindl wrote:
> Am 30.07.12 22:42, schrieb Tex Iano:
>> Hi,
>> that purpose, I am thinking about migrating from XMI files to Teneo.
>> Is Teneo already applicable for productive use or is it still a
> Yes. Teneo is stable and we are using it in a number of RCP projects
> very successfully!
>> Regards,
> Well DB-Schema-Evolution is not a simple thing. Hibernate has some
> schema evolution but we are doing the schema evolution by hand.
> Our process is like this:
> a) Generate the hbm.xml from the ecore
> b) Generate the DDL from the hbm.xml using Hibernate
> c) Store the DDL in the VCS
> d) Update the .ecore
> e) => back to step a)
> f) Diff the change in the DDL and write an alter script by hand
> Tom
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
FUDForum. Page generated in 0.03190 seconds
