Home » Modeling » EMF » Model file suffix mandatory
Re: Model file suffix mandatory [message #899172 is a reply to message #899138] |
Mon, 30 July 2012 20:38 |
Ed Merks Messages: 33140 Registered: July 2009 |
Ralph,
Comments below.
On 30/07/2012 6:17 PM, Ralph P wrote:
> I defined an ECORE model called "MyModel".
> The generated wizard creates XML files with the suffix .mymodel which
> can be edited with the corresponding generated editor.
> My problem is, that the editor throws an exception when the suffix is
> not .mymodel (see below). Why does that happen?
Because the right factory is registered in the plugin.xml based on the
suffix; have a look.
> How can this error make sense?
> org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'MyModel' is
> not found or is abstract. (platform:/resource/MyProject/Model.xml, 2, 73)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.validateCreateObjectFromFactory(XMLHandler.java:2244)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.validateCreateObjectFromFactory(XMLHandler.java:2235)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType(XMLHandler.java:1332)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XMLHandler.java:1468)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XMLHandler.java:1019)
> at
> org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMIHandler.java:83)
> Is there a way to enable other suffixes as well or make it irrelevant
> which suffix the XML file must have?
Yes, but if you want to use a commonly used suffix like *.xml, you'll
need to use content types. You can do that by defining a content type
identifier for the GenPackage and changing the suffix to what you want
to use. Be sure the delete the plugin.xml and regenerate it and have a
look at what's generated to understand it better.
> Thanks in advance!
> Regards,
> Ralph
Ed Merks
Re: Model file suffix mandatory [message #899242 is a reply to message #899235] |
Tue, 31 July 2012 08:18 |
Ralph,
There can be only one resource factory registered against *.xml, so if
everyone does this, there will be one winner and lots of losers...
On 31/07/2012 10:05 AM, Ralph P wrote:
> Hello Ed,
> thanks for the reply!
> I don't fully understand you, but you still brought me a solution.
> I just defined two more org.eclipse.emf.ecore.extension_parsers
> extensions with different types/suffixes (one of them is 'xml') which
> point at the same ResourceFactory. It seems to work fine. Is there an
> argument not to do it that way?
> Quote:
>> to use.
> This is what I don't understand. Do you mean defining a new Content
> Type via an Eclipse extension in the plugin.xml? How do I refer to the
> "GenPackage"?
When you open the *.genmodel, the GenPackage is the second level of
nesting. If you selected it, you'll see all the properties you can
specify for a GenPackage, one of which is the Content Type Identifier.
> Quote:
> You mean the generation process of the model code is affected by the
> content types?
Of the plugin.xml yes. The content type identifier also produces a
constant in the generated XyzPackage.
> Does this mean I need to have the content type defined in my
> development environment?
Yes, EMF will generate the right things for you.
> Regards,
> Ralf
Ed Merks
Re: Model file suffix mandatory [message #899530 is a reply to message #899519] |
Wed, 01 August 2012 10:14 |
Ralf,
Comments below.
On 01/08/2012 11:29 AM, Ralph P wrote:
> Hi Ed,
> regenerating the plugin.xml in the editor plug-in created a content
> type binding properly, but it had nothing to do with registering the
> factory properly.
> But I found out that the reference to my content type in the was
> "<model plug-in ID>.model", while in the content_parser extension it
> was only "model".
Ah yes, if the ID isn't qualified at all, PDE implicitly qualifies it.
You really should use a qualified name in the first place; something
globally unique, like Java package names.
> So I changed the "contentTypeIdentifier" attribute value manually to
> "<model plug-in ID>.model" - and it worked!
> I also had to change the eCONTENT_TYPE constant of the ModelPackage
> interface, because the finish action of the generated wizard could
> also not resolve the "model" content type ID.
As long as the plugin.xmls were regenerated after your changes to the
*.genmodel, everything should align...
> Anyways, it's now working 100% how I want it to be! Thank you very much!
You're welcome.
> Regards,
> Ralf
Ed Merks
Current Time: Thu Apr 25 14:17:59 GMT 2024
Powered by FUDForum. Page generated in 0.03272 seconds
