Home » Eclipse Projects » P2 » How is installFeature action supposed to work?
How is installFeature action supposed to work? [message #899135] Mon, 30 July 2012 15:53 Go to next message
Thorsten Meinl is currently offline Thorsten MeinlFriend
Member
Hi all,
We are currently facing the problem of turning an implicitly installed
feature (from a feature dependency) into a root feature via an update to
the RCP application. I though that could be accomplished with the
installFeature touchpoint action, but this does not work, because the
feature to be installed by this action must be among the artifacts of
the current feature. This is obviously not the case, I have never seen
an feature.group being the artifact of another feature (is this even
possible?). This is a bit disappointing since this seemed to be the only
way of accomplishing the task. Two question:
1. Why is installFeature restricted to artifacts of the current IU
(which in almost all cases does not make sense I believe)?
2. Is there another way of turning a non-root IU into a root IU without
explicitly installing the IU?
The overall goal is to make the non-root IU uninstallable, which isn't
possible if it isn't a root IU (only).
Thorsten
Re: How is installFeature action supposed to work? [message #899306 is a reply to message #899135] Tue, 31 July 2012 12:30 Go to previous messageGo to next message
Henrik Lindberg is currently offline Henrik LindbergFriend
We had the same/similar issue in cloudsmith / geppetto @ github. Our
solution was to ship a "run once" bundle that used the p2 API to make
the modifications.
- henrik
On 2012-30-07 17:53, Thorsten Meinl wrote:
> Hi all,
> Cheers,
> Thorsten
Re: How is installFeature action supposed to work? [message #899357 is a reply to message #899306] Tue, 31 July 2012 14:24 Go to previous messageGo to next message
Member
Hi Hendrik,
Could you point me to or send me more details on how you did this?
Thorsten
Am 31.07.2012 14:30, schrieb Henrik Lindberg:
> the modifications.
> Regards
> - henrik
>> Hi all,
>> Cheers,
>> Thorsten
Re: How is installFeature action supposed to work? [message #899586 is a reply to message #899357] Wed, 01 August 2012 14:08 Go to previous message
On 2012-31-07 16:24, Thorsten Meinl wrote:
> Hi Hendrik,
The code for the "run once" is here:
https://github.com/cloudsmith/geppetto/blob/master/org.cloudsmith.geppetto.onetimeinstall/src/org/cloudsmith/geppetto/onetimeinstall/Activator.java
Hope that helps you.
- henrik
> Thorsten
>> the modifications.
>> Regards
>> - henrik
>>> Hi all,
>>> Cheers,
>>> Thorsten
Previous Topic:The required Touchpoint: org.eclipse.equinox.p2.native 1.0.0
Next Topic:p2 and UAC
Current Time: Thu Jan 23 01:55:09 GMT 2025
Powered by FUDForum. Page generated in 0.04011 seconds
