Home » Eclipse Projects » Remote Application Platform (RAP) » create a RAP Launch based on feature
create a RAP Launch based on feature [message #899105] Mon, 30 July 2012 14:58
Lorenzo Bettini is currently offline Lorenzo BettiniFriend
I've just started using RAP; currently, I have a plugin for single
sourcing with optional features like org.eclipse.ui and
org.eclipse.rap.ui so that in the launch configuration I disabled
org.eclipse.ui stuff and select org.eclipse.rap.ui stuff and it all works...
I'd like to avoid to configure the launch by selecting/unselecting
plugins, so I created a feature project and a RAP launch configuration
based only on that feature.
In this feature I have only rap.ui plugins, however, when I run this
launch, the eclipse.ui stuff is used...
am I doing something wrong, or RAP launch configurations based on
features are not possible?
At the end you find the plugins in my feature.xml (I also use emf rap
versions for ui)
thanks in advance
Lorenzo
<plugin
id="org.eclipse.equinox.http.registry"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.equinox.http.servlet"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.emf.rap.common.ui"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.emf.rap.edit.ui"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.equinox.console"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.apache.felix.gogo.shell"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.equinox.http.jetty"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.rap.design.example"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.rap.jface"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.rap.jface.databinding"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.rap.rwt"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.rap.rwt.osgi"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.rap.ui"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.rap.ui.cheatsheets"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.rap.ui.forms"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.rap.ui.views"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.rap.ui.workbench"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.emf.rap"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Previous Topic:Text Widget spaces the TAB
Next Topic:please help for server push?
Current Time: Tue Apr 16 08:25:08 GMT 2024
Powered by FUDForum. Page generated in 0.91526 seconds
