Home » Archived » BIRT » Passing file to remote server(Using a XML file parameter)
Passing file to remote server [message #899090] Mon, 30 July 2012 14:18 Go to next message
Dave C is currently offline Dave CFriend
Hello!
I'm using a XML file parameter for the data source (thanks again Jason!) that I pass in the URL etc. This is working great on my machine, but the next step would be having this setup work with the viewer running on a remote server running tomcat.
I've searched high and low for examples of how to do this and am starting to think it isn't possible! Smile
Is it possible to use a local file as a report parameter for a report located on a remote server? The local machine and server (at least for this test) are located on the same network, so they should be able to see each other.
Can the XML file be saved on a network drive and accessed or does the file have to be located on the server itself that is running tomcat?
Thanks again for your help! I'm really enjoying working with Birt!
Re: Passing file to remote server [message #899162 is a reply to message #899090] Mon, 30 July 2012 17:24 Go to previous message
Jason Weathersby is currently offline Jason WeathersbyFriend
Dave,
The xml file has to be accessible either through a url or file from the
server.
Jason
On 7/30/2012 10:18 AM, Dave C wrote:
> Hello!
> starting to think it isn't possible! :)
> see each other.
Previous Topic:can't load birt-viewer on hosting,frameset was not recognized
Next Topic:How to change Y Series to reflect data in chart
Current Time: Tue Apr 16 18:03:15 GMT 2024
Powered by FUDForum. Page generated in 0.86667 seconds
