Re: Couldn't resolve reference to JvmIdentifiableElement 'generateStub'. [message #899179 is a reply to message #899041] |
Mon, 30 July 2012 21:23 |
Kai Kreuzer Messages: 673 Registered: December 2011 |
I've had the same when I upgraded to 2.3.0.
Unfortunately, I do not recall what exactly made it disappear.
I suppose it could be related with the fact that Xtend has been split of Xtext - so try to make sure that you have the Xtend SDK 2.3.0 installed in your IDE - the SerializerFragment is resolved as an Xtend class inside org.eclipse.xtext.generator_2.3.0; this class has a setGenerateStub method, so everything looks fine.
Could you check where your SerializerFragment resolves to (the version of the bundle as well as if it is a java class or an xtend class)?
[Updated on: Mon, 30 July 2012 21:25] Report message to a moderator
FUDForum. Page generated in 0.03560 seconds
