Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Getting errors when invoking sortedBy (Does sortedBy work with expressions that are invokation to a custom query that retrieves a tagged value from a stereotype?)
[Acceleo] Getting errors when invoking sortedBy [message #898902] Sun, 29 July 2012 03:26 Go to next message
Tomas Balderas is currently offline Tomas BalderasFriend
Member
In the following code operandIndex() is a query that retrieves the value of a tagged attribute from the stereotype extending an instance of the metaclass InputPin:
[anOpaqueAction.input->asSequence()->sortedBy(operandIndex())/];
This code does not produce any error and generates some text with internal information about the objects for the input pins of the receiving object anOpaqueAction. However, when I use the sorted list as the receiver of a template (any template, including an empty one), I get errors. This is the code:
[anOpaqueAction.input->asSequence()->sortedBy(operandIndex())->generateExpression('&')/];[/for]
[template public generateExpression(aSequence: Sequence(InputPin), anOperator: String)]
[/template]
The errors are as follows:
Operation operandIndex() is undefined on type org.eclipse.uml2.uml.internal.impl.InputPinImpl.
Undefined argument anOpaqueAction.input->asSequence()->sortedBy(temp1 : InputPin | temp1.operandIndex()) of invocation at line 0 in Module generateArchitectureStatementPart for block generateExpression(anOpaqueAction.input->asSequence()->sortedBy(temp1 : InputPin | temp1.operandIndex()),'&'). Last recorded value of self was org.eclipse.uml2.uml.internal.impl.OpaqueActionImpl@6e833131 (name: merge, visibility: <unset>) (isLeaf: false) (body: null, language: null). Problem found while generating the file ...
What am I doing wrong?
/TB
Re: [Acceleo] Getting errors when invoking sortedBy [message #898946 is a reply to message #898902] Sun, 29 July 2012 07:24 Go to previous messageGo to next message
Hi Tomas
This seems vaguely familiar. Acceleo or OCL has trouble with
over-complex collections.
Try using an intermediate let-variable.
Ed Willink
> [/template]
> Thanks
Re: [Acceleo] Getting errors when invoking sortedBy [message #898977 is a reply to message #898946] Sun, 29 July 2012 23:06 Go to previous message
Member
Thank you Ed
You have saved my life, as before. I implemented your suggestion and everything worked fine!
Kindest regards.
/TB
Previous Topic:[Acceleo] how to create a compiler with xtext and Acceleo ?
Next Topic:XPand2 / MWE: Load file for XPand generator from outside the Java classpath?
Current Time: Tue Nov 24 19:09:56 GMT 2020
Powered by FUDForum. Page generated in 0.02077 seconds
