How to add a perspective dynamically [message #898859] |
Sat, 28 July 2012 10:35 |
Gabriel Llamas Messages: 1 Registered: July 2012 |
I want to add a perspective dynamically from the code without using the plugin.xml file. All the information I've obtained about this is that's impossible without "hacking" the Equinox plugin.
Please, see: https://bugs.eclipse.org/bugs/show_bug.cgi?id=295035
The problem is that I cannot add a contribution to the ExtensionRegistry because I need a user or master token, but these tokens cannot be obtained from anywhere, they are created and used internally by the Equinox plugin. The reason they give is to prevent the plugins to add "heavy consuming memory stuff".
The guy that posted the "bug" in the previous link ended with a workarround but he didn't post the solution. The post was made in 2009.
Now, 3 years later what's the status about this? How can I add perspectives dynamically?
This is what I have:
String perspective =
"<extension " +
"point=\"org.eclipse.ui.perspectives\">" +
"<perspective " +
"class=\"perspectivefactory.PerspectiveFactory2\" " +
"icon=\"icons/error.gif\" " +
"id=\"Perspective Creator.perspective2\" " +
"name=\"name\">" +
"</perspective>" +
"</extension>";
try (InputStream in = new ByteArrayInputStream (perspective.getBytes (Charset.defaultCharset ()))){
IContributor contributor = ContributorFactoryOSGi.createContributor (Platform.getBundle (Activator.PLUGIN_ID));
Platform.getExtensionRegistry ().addContribution (in, contributor, false, null, null, null);
}catch (UnsupportedEncodingException e){
}catch (IOException e){
Utils.log (e);
but I get the error:
org.eclipse.e4.core.di.InjectionException: java.lang.IllegalArgumentException: Unauthorized access to the ExtensionRegistry.addContribution() method. Check if proper access token is supplied.
That's because I need a master token. using Reflection I can get it:
public static boolean addContribution (String contribution){
boolean added = false;
new ByteArrayInputStream (contribution.getBytes (Charset.defaultCharset ()));){
IExtensionRegistry registry = Platform.getExtensionRegistry ();
* To add a contribution we need a user or master token. These tokens cannot be
* obtained explicitly because the Equinox bundle creates and uses them internally
* to prevent the addition of heavy consuming memory stuff.
* See: https://bugs.eclipse.org/bugs/show_bug.cgi?id=295035
* But there's still a way to obtain a master token. See below. The warning
* supression is because the unauthorized access to the ExtensionRegistry.
@SuppressWarnings ("restriction")
Field field =
org.eclipse.core.internal.registry.ExtensionRegistry.class
.getDeclaredField ("masterToken");
field.setAccessible (true);
Object masterToken = field.get (registry);
added = registry.addContribution (in, contributor, false, null, null, masterToken);
}catch (NoSuchFieldException e){
Log.error (e);
}catch (SecurityException e){
Log.error (e);
}catch (IllegalArgumentException e){
Log.error (e);
}catch (IllegalAccessException e){
Log.error (e);
Log.error (e);
return added;
This function returns true with the following addition but when I search in the perspective registry I can't find it.
boolean added = Registry.addContribution (
"<extension " +
"<perspective " +
"class=\"gll.perspective_creator.ui.EmptyPerspective\" " +
"icon=\"images/error.gif\" " +
"id=\"gll.perspective_creator.emptyPerspective\" " +
"name=\"Empty Perspective\">" +
"</perspective>" +
"</extension>");
So, concluding, how can I add a perspective dynamically?
Thanks.
Re: How to add a perspective dynamically [message #899001 is a reply to message #898859] |
Mon, 30 July 2012 06:25 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
You won't get a solution to this in 3.x - in 4.x the model is accessible
to anyone so you can add perspectives, ... link you want it.
So what version of Eclipse are you targeting?
Tom
Am 28.07.12 12:36, schrieb Gabriel Llamas:
> "<extension " +
> "<perspective " +
> "name=\"name\">" +
> "</perspective>" +
> "</extension>";
> Utils.log (e);
> is supplied.
> tokens cannot be
> * * But there's still a way to obtain a master token.
> ExtensionRegistry.
> Field field =
> null, masterToken);
> Log.error (e);
> Log.error (e);
> Log.error (e);
> Log.error (e);
> Log.error (e);
> return added;
> "<extension " +
> "<perspective " +
> "</perspective>" +
> "</extension>");
> Thanks.
FUDForum. Page generated in 0.03196 seconds
