Home » Modeling » EMF » [TENEO] Inheritance Mapping Limitation
[TENEO] Inheritance Mapping Limitation [message #898617] Thu, 26 July 2012 21:45 Go to next message
fabiangec Missing name is currently offline fabiangec Missing nameFriend
How I can solve this limitation?
http://wiki.eclipse.org/Teneo/Hibernate/ModelRelational/Inheritance_Mapping#Limitation
Re: [TENEO] Inheritance Mapping Limitation [message #898635 is a reply to message #898617] Thu, 26 July 2012 23:18 Go to previous messageGo to next message
Martin Taal is currently offline Martin TaalFriend
You have a multi-inheritance case then? You can't really (otherwise I would have solved it long ago), you have to change
your model. If you can post your model with some info maybe I can comment in more detail for your specific case.
gr. Martin
On 07/26/2012 11:45 PM, fabiangec Mising name wrote:
> How I can solve this limitation? http://wiki.eclipse.org/Teneo/Hibernate/ModelRelational/Inheritance_Mapping#Limitation
> Thanks
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [TENEO] Inheritance Mapping Limitation [message #898788 is a reply to message #898635] Fri, 27 July 2012 14:52 Go to previous messageGo to next message
It should not be so easy to solve not already done so. My question is if you have somehow, by means of annotations can be made that do not generate the Foreign knowing that you may lose consistency in the model. thank you very much
Re: [TENEO] Inheritance Mapping Limitation [message #898791 is a reply to message #898788] Fri, 27 July 2012 15:09 Go to previous messageGo to next message
Hi Fabian,
Sorry can you explain a bit more? What foreign key you don't want to have generated?
gr. Martin
The Netherlands
Re: [TENEO] Inheritance Mapping Limitation [message #898826 is a reply to message #898791] Fri, 27 July 2012 19:14 Go to previous message
Already resolve the issue using the notation ANY. For the example in question would be to put an annotation in the eReference AssetList-Asset and thus @Any(metaColumn = @Column(name = "assetList_asset_type"))
Thus the FK on the table SchoolBook AssetList not generated and I can enlist SchoolBook instances if you had put heritage in the first place and not to Asset Book.
Thanks for your help
Previous Topic:[Diff/Merge] Creation Review successful
Next Topic:[xcore] refering to classes in non XCore ecore models
Current Time: Fri Dec 06 22:35:44 GMT 2019
Powered by FUDForum. Page generated in 0.01836 seconds
