Re: recover lost work "resource is out of sync with the file system eclipse" [message #972942 is a reply to message #898420] |
Tue, 06 November 2012 01:21 |
Drake Christensen Messages: 6 Registered: November 2010 |
This just started for me.
This is a toy Android project that I've been playing with. (I'm surprised to see that it has been a year since I last looked at it. Doesn't feel like that long.) Last time I messed with it everything worked fine.
I've tried refreshing the project. The error message says that the error is with default.properties, and I've tried refreshing that file. I've set the auto-refresh flag. I've tried "Compare with" and it says there is no local history to compare with. (Looks like it would have aged off when I fired it up.) I've tried shutting down and restarting Eclipse a couple of times. I've tried altering the project from within Eclipse and I can see that the file in question is altered.
I don't think I've touched anything at all in my Eclipse workspace directory. The only thing that I can think of that even looked in there are a couple of backup programs that I've tried out. But, the only thing either of them should change is the archive bit.
I've been searching around and the only two fixes I've come across are to refresh and compare to local files. Is there something else that can trigger this message? Is there some other way to clear it?
Eclipse IDE for Java Developers
Version: Helios Service Release 1
Build id: 20100917-0705
Drake
[Updated on: Tue, 06 November 2012 01:22] Report message to a moderator
FUDForum. Page generated in 0.10678 seconds
